Need Rewooding Advice
Topic author - Posts: 2289
- Last Name: House
- MTFCA Number: 115
A friend of mine needs to replace a 24 roadster door hinge rib or pillar. I have Mel Miller’s wood blueprints for a 14-21 roadster. What, if anything, is common or appropriate for his roadster and my wood plans ? I know the hinge is different. Thanks all !!
I don’t know why I turned out this way. My parents were decent people.
- MTFCA Number: 28924
Re: Need Rewooding Advice
I thought the open car door hinges were the same up to 1925 when they were changed to a straight hinge. The door wood from the different body makers may be a little different but they would fit the door openings.
- Last Name: House
- MTFCA Number: 115
No, John prior to the ‘24 Model year the open car hinges appeared-when opened- as a triangle with a flat top. But thanks for the input. I’ll post a picture.
- MTFCA Number: 52564
The body parts book shows the same hinge thru 1924 then the new style for 25.
1920 Dodge touring
1920 Dodge touring
my '23 came with the wrong hinge and was retrofitted back to correct when I rewooded. As I recall, the only difference was in the location of the screw holes. The physical outline matched the sheetmetal perfectly. Since you're replacing that pilar, I think you're going to be fine.
NH Full Flow Float Valves
- Last Name: House
- MTFCA Number: 115
The early to body style 1923 is the one on the right (upside down) . The 24-25 is represented by the pic on the left .
I was thinking the body parts book lists the same hinge thru 24. Lang’s lists the reproductions as being from 14-25.
- Last Name: House
- MTFCA Number: 115
If that’s the case, where do all these rectangular (red oxide primer in my pic above) fit in ? The New and Improved open car hinges are totally different. Other than me; who else has seen an unmolested ‘24 touring or roadster with a hinge as I stated above ? That rectangular hinge isn’t a 1 Year only design.
What is the build date?
1920 Dodge touring
1920 Dodge touring
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
most of the rectangular ones i have are on steel ribs not wood.charley
- First Name: Kathy
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1917 Runabout, 1918 Coupelet, ‘21 Centerdoor, ‘22 coupes, ‘23 Roadster and touring, ‘25 roadster pickup, Fordor, and coupe, ‘26 Coupe
- MTFCA Number: 32467
- MTFCI Number: 24412
Got the passenger side door hinge post and top "s twist" piece for our 23 Roadster. Classic Wood Products "Ricky" was great! had the pieces to me within 2 weeks. I know they can't work that fast for everything - but what a great guy to talk to ! Now to fit them in. The only 2 pieces found to be rotted and appears someone thought putting more screws into rotted wood worked (NOT).
- First Name: Hap
- Last Name: Tucker
- MTFCA Number: 100
George,
There is always more to learn, but it appears the equal length hinge was introduced around Aug 1924. The earliest equal length hinge in the thread discussion at:
http://www.mtfca.com/discus/messages/80257/114100.html had an engine number #10,377,xxx and belonged to Dan Treace at the time. It also had the wooden door post. Note I believe Dan had a type-o in his post when he said it was built Aug 16, 1924. Bruce McCalley's engine serial number log shows "no engine" numbers assigned or stamped onto engines on Aug 16, 1924. But for Aug 26, 1924 they had engine serial numbers 10,375,722 to 10,382,721 produced (or the number sent to a branch plant that assembled engines and stamped that number on the engine they assembled).
Note --- Ford did not really like "model years" but General Motors used them to sell new models quite successfully. Based on the current information I have seen so far, I believe that equal length hinge was basically a one year item "in USA production." I.e. Aug 1924 to Aug 1925 when the 1926 Improved Models were introduced in the USA. From the posting listed above, the equal length hinge was apparently used as early as Aug 1924. It may have possibly been earlier -- but I don't have any supporting documentation on an earlier use. If anyone else does, we would welcome that data point.
I suspect that some plants in other parts of the world began producing the 1926 style open cars later than the USA. And "IF" those plants in other countries continued the USA 1925 style body -- then they would have continued the 1925 style hinge longer.
Note the price list of parts was mentioned above but it does not always answer the question in a nice clean manner. For Mark -- from Bruce's Encyclopedia he has:
And from that -- I don't have time to figure out why they list the same door hinge for 1912-1917 in the 1917 price list of parts. Perhaps Bruce made a type-o? Or perhaps they used the same factory number for the part and figured the owner would list the year of the car and they could then supply the correct hinge?
But the Sep 1920 price list of parts has factory number 5297 fitting 1914-1920.
The Dec 1921 price list of parts has it fitting 1914-1921 (again if they were using "model year it could have said 1922 -- but that is a different question)
The Sep 1923 price list of parts has it fitting 1914-1923.
The Mar 1927 price list of parts has it fitting 1914-1924 [NOT 1925]
Note in the Apr 1925 price list of parts a NEW FACTORY number 20022 in used and is listed as fitting 1924-1925.
The Mar 1927 price list of parts has that same Factory number 20022R (R for replacement) and still listed 1924-1925.
Note the MTFCI (International) Judging Guidelines 7th Edition list the equal length door hinges for the 1925 and not the 1924 year cars.
I suspect that in Aug 1925 there were some cars produced with the older style hinge and some produced with the newer style hinge. And the ones with the older style would be looked at as 1924 models and the ones with the later style hinge would be considered 1925 models using that judging guideline.
I do not know how long that overlap lasted.
Not requested -- but some advice offered for free and maybe not worth that much. If your friend is restoring the car for Stynoski competition, and it is an early 1924 car (i.e. before Aug 1924 etc. I would recommend the 1914-1924 style hinges unless he has documentation supporting the equal length hinges that early. Note there may be a Factory Drawing for Factory Number 20022 at the Benson Ford Archives. If so, it may have the original date the part was drawn up. And normally the parts are NOT produced before the Factory Drawing is made telling the folks the dimensions etc. of how to make the part.
If they are working towards a good driving T -- either hinge will work with car and door.
Respectfully submitted,
Hap l9l5 cut off
Minor Rabbit trail: Did the C-Cab Ton Truck use the same hinge as the open cars? If so then the hinge continued into calendar year 1927 when the last 91 C-cabs were produced (ref page 173 of Bruce's book "Model T Ford.")
Hap l9l5 cut off
- Last Name: Dewey
- MTFCI Number: 19936
I don't know if you have a '24 or a '25 YEAR MODEL car, but here is what the hinge and pillar look like on a 1925 year model runabout. Note that although the door is still wood-framed, as is the latching pillar, the hinge pillar is all metal.
Note that the '25 YEAR MODEL door latch pillar part has only two screws holding it in place.T'ake care,
David Dewey
David Dewey
- Last Name: House
- MTFCA Number: 115
Many thanks Hap - and you too David. As usual, I learn many tidbits of useful information from your research and diligence at correctitude (new word). So. The rectangular appearing hinge IS a 1 Year part,huh? And I didn’t know ol’ Henry didn’t like to use ‘Model years’ in discussion. I’ve been in that ‘model year’ habit for years. So much so that I just spent 2 days tearing down a 1919 engine for rebuild as a spare for my ‘19 center door only to realize the casting date is
11 7 19. That’s a ‘20 MODEL YEAR so I won’t use it. Thanks again to all !!
- Last Name: Dewey
Yes, the '25s are almost a creature unto themselves. And yes, Henry did not like to talk about "Year Models" as he disliked the idea that you would be goaded into buying a new car just because of a year model change--but the T did change over time, and the changes USUALLY occurred a bit after the middle of a calendar year. Back about 40 years ago, well-intentioned folks would "correct" all the "wrong" parts on their cars only nowadays to find out those actually were the correct parts!
T'ake care,
David Dewey
David Dewey
