Early Clutch Slip Ring - Newer Drive Plate
Posted: Thu May 07, 2020 5:11 pm
by fbergski
Unknown to me newer clutch drive plates do not have the keyway cut into them as the early clutch drive plates have. I had to use a newer drive plate for my 11 trans rebuild, the clutch slip ring has a slot for a keyway. The question is can I still use it or get a later slip ring?
Thx
Re: Early Clutch Slip Ring - Newer Drive Plate
Posted: Thu May 07, 2020 5:39 pm
by Kerry
Yes you can.
