Pealing off laminated shims.
Posted: Sun May 10, 2020 11:00 am
by John Illinois
Is there a good way to separate shims ? I alway have difficulty pealing off the thinnest shim. Finger nail,sharp knife?
John
Re: Pealing off laminated shims.
Posted: Sun May 10, 2020 11:02 am
by RajoRacer
I've used a small Exacto hobby knife before AND a magnifying visor ! I seem to recall reading something about heating up one end to delaminate the adhesive ?
Posted: Sun May 10, 2020 11:16 am
by Dan McEachern
Yup- Exacto knife.
Posted: Sun May 10, 2020 12:22 pm
by modeltbarn
Heat a corner with a small lighter to soften the adhesive, then us a sharp blade. I use a utility knife because it has a good handle and supports the blade well, but a single edge razor blade or exacto knife work as well.
Posted: Sun May 10, 2020 1:29 pm
by Jerry VanOoteghem
I do more than heat the corner. I hold a propane torch near the shim stack until the adhesive, (paraffin?), burns away. They all come part nicely then. You obviously don't want to melt them...
Posted: Sun May 10, 2020 4:05 pm
by John kuehn
I have good luck with single edge razor blades. That work fine for me.
Posted: Sun May 10, 2020 5:08 pm
by John Illinois
Thanks for all the ideas. I will work on some shims tomarrow.
John
Posted: Sun May 10, 2020 6:35 pm
Jerry VanOoteghem wrote: ↑Sun May 10, 2020 1:29 pm
A refinement on my suggestion above would be to put a tie wire through the hole and hold the shim over a stove flame, (which in retrospect, is what I actually did).
Posted: Sun May 10, 2020 7:05 pm
by Steve Hughes
I don’t want the whole pack to come apart so I hold it with a pliers a ways from one end. Then hit the end with the torch.
Posted: Mon May 11, 2020 5:13 pm
by John Illinois
I had good luck heating the shims with a micro torch. I held one end and heated just the outer layer all over. The outside layer would curl and loosen. They came off one at a time. The forum helps me once again.
John
Posted: Mon May 11, 2020 10:21 pm
by StanHowe
Take your soldering gun, hold it on the pack until the top one slides off. Repeat as needed.
Posted: Tue May 12, 2020 10:35 am
by Original Smith
I have used an x-acto knife too, as well as a single edge razor blade. What I don't like is the shims are usually .003" which is too thick for close adjustments. I have to make my own .001" shims to get the adjustments I want.
