installation instructions for side view mirror
Topic author - Posts: 1315
- First Name: Robert
- Last Name: Jablonski
- MTFCA Number: 407
Would anyone have the installation instructions for side view mirror sold by our vendors with a solid 8-in mounting bar and a 5-in round mirror. There was advertised a download for instructions but the vendors having problems. Spoke to vendors office but have not received any information or download. Not sure if mirror bracket for 26-27 open car gets installed on upper or lower windshield studs.
- MTFCA Number: 4838
- MTFCI Number: 115
Re: installation instructions for side view mirror
Haven't used that type, but appears the new longer wingnut stud replaces the factory stud inside the cone of the windshield frames.
IMO, at the upper frame wing nut, the arm would be rather close to the top front bow. Seems mid way a the lower frame would be ok, but its your choice, the higher spot may be better. Just sit in the T and hold it in either position to see what the view is behind you.
The lower location works for me on the '27, but this is Antique Motor Sports's mirror, however it is installed with a drilled hole in the stanchion, so I used the lower position near the curtain Lift- the- Dot stud. That put the mirror head at my easy eye level.
Cut off part of the hex-head on a bolt to sit deep in the channel, that's covered with the weather strip in the channel. Capped the bolt with a stainless dome nut. I like this type mount, even if a hole is made, as the arm is always fixed securely to the stanchion, minimum wiggle.
- MTFCA Number: 28924
I have a vendor supplied rear view mirrow that I use on my 21 Touring. The mounting holes are drilled for the 2 holes on the windshield posts and it’s mounted there. If the mounting holes will fit the lower or upper studs maybe it’s meant for the driver to mount it in the best rear view location for your paticular car. Not sure about that though.
Whichever one you use it will work best on the most stable location to lessen vibration. That would be something to consider.
It’s up to you but having a rear view mirrow on both sides really helps. When I installed the one I bought on the drivers side of my 21 Touring I decided to make another mounting arm out of some bar stock I had in my junk pile. They are easy to make and I had another round mirrow my Grandfather used for a rear view mirrow in the 24 Coupe I inherited from him. It was the same size as the new one I bought and it matched really well.
- MTFCA Number: 407
Thanks John and Dan for your quick responses. Since I am 6'2 and sit relatively tall , hanging at side view mirror from the top wing nut will suit me just fine. Thanks for your help, appreciated !!!
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
I tried mounting mine on the lower half of the windshield. It just wasnt right for me. I did not feel I could see to the rear well enough. Then I tried the upper half of the windshield. Maybe I just like looking up, but I felt I could see items in the rear much better. View was not blocked by my lowered top either.
- MTFCA Number: 407
To those who have purchased this side view mirror assembly... Have you had problems with the included threaded windshield attachment not fitting through the hole that's in the side view mirror bracket?
- MTFCA Number: 407
Thank you Dave
