Windshield and glass replacement help needed
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 26 & 24 coupe, 25 pickup, and 26 Fordson.
MTFCA Number: 31639
MTFCI Number: 31639
Post by Modeltmike » Sun May 17, 2020 4:47 pm
I am removing the original glass from my 24 coupe. I have taken the measurements from the old glass. The new laminated glass will be 1/4 thick and should fit in the channel. Likely not enough space to put the fabric in the channel like original. I have seen people put a bead of clear silicone and install glass. I have not had the glass cut yet.
Any ideas or guidance with experience would be helpful.
Anyone have the glass measurements for a 24 coupe to compare with what I removed?
Mike
Re: Windshield and glass replacement help needed
Post by Allan » Mon May 18, 2020 1:19 am
Mike, I would leave it to the glass shop to use whatever mounting materials they use in their everyday work. Most times this will be a black mastic type product. Sikaflex is one brand of glass mounting material.
With windscreens a big advantage is these materials preclude water, so the rust problem is eliminated.
Hope this helps.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Mon May 18, 2020 9:03 am
This has '24 closed body glass dimensions.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Mon May 18, 2020 10:03 am
Mike, do what Allen just said. Let those who deal with it daily handle it. It's worth the money. You break your glass once, maybe twice, trying to install it, now you've spent more than what it would be to let them do it. I've done two sets of windshields through the glass company and no regrets.
