1927 T Coupe Windsield Hinge Rubber
daveclause
First Name: D
Last Name: R
Board Member Since: 2004
Post by daveclause » Mon May 18, 2020 1:51 am
I am helping a buddy restore his T Coupe. Our problem is with the windshield hinge weather stripping.
We don't know how it is supposed to fit. We don't know if it is supposed to slide in to the rail or if it lays flat on top and we punch holes for the 1/4 x 20 screws.
How does it fit?
Thank you for any input.
I have attached some pics.
1. Hinge with out weather stripping.
2. Hinge with weather stripping started in the channel.
3. Hinge with weather stripping laying flat on top.
cve92
First Name: Carl
Last Name: Finchum
* REQUIRED* Type and Year of Model Ts owned: 1919 touring
MTFCA Number: 49474
Re: 1927 T Coupe Windsield Hinge Rubber
Post by cve92 » Mon May 18, 2020 5:15 am
I need the same thing. May I ask where you got the rubber strip from. I wish I could help.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Mon May 18, 2020 6:30 am
My '26 Coupe only has rubber down the sides and along the bottom. I don't get leaks along the top because of the hinge.
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Mon May 18, 2020 7:53 am
Yup, it goes on sides and bottom only. Hard to see from your picture, but am not sure you have the right seal for a closed car windshield.
bulman
First Name: gary
Last Name: baker
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
MTFCA Number: 31985
Post by bulman » Mon May 18, 2020 7:59 am
I tried this on my 26 coupe it made the windshield too low and wouldn't close.I took it off and the w/s works just fine.I can't say about leaks because I am still reassembling it.Just my experience.
daveclause
First Name: D
Last Name: R
Post by daveclause » Mon May 18, 2020 1:56 pm
Have the rubber on the sides and the bottom. There is also a seal that goes on top of the windshield hinge.I don't know if we are using the wrong rubber seal or not. He got it from MAC's.
But, yea, there is a seal that is supposed to be used.
daveclause
First Name: D
Last Name: R
Post by daveclause » Mon May 18, 2020 5:20 pm
Can someone post a photo of theirs with the rubber gasket on the hinge?
jab35
Last Name: Bartsch
MTFCA Number: 30615
Post by jab35 » Mon May 18, 2020 8:35 pm
Dave: My original '26 coup does not have a seal on the top hinge, the visor apparently gives some protection keeping most water out. If anything were sandwiched between the hinge and body my windshield would not close, it's a tight fit as it is. best, jb
