Front axle?
Posted: Fri May 22, 2020 4:48 pm
by Wwbbim
So I am confused about 4 different parts on my 1922 roadsters front axle. When I got the old parts, this is how it came assembled. I have redone the parts but am still co fused if they go like that? It is the parts that attach to the front axle spring(where it went when I got it) and attached to the actual axle.[image][image][/image][/image]
Re: Front axle?
Posted: Fri May 22, 2020 4:56 pm
by Dan Hatch
Where is the coil spring?
Re: Front axle?
Posted: Fri May 22, 2020 4:59 pm
by Wwbbim
Re: Dan Hatch it was separated at the time we took the pictures
Re: Front axle?
Posted: Fri May 22, 2020 5:01 pm
by Mustang1964s
Take a look at this thread.
http://www.mtfca.com/discus/messages/25 ... 1339967930
It shows some good close ups.
Re: Front axle?
Posted: Fri May 22, 2020 5:04 pm
by Wwbbim
Thanks Mustang 64‘s that makes a lot more sense
Re: Front axle?
Posted: Fri May 22, 2020 10:24 pm
Instructions and a caution. Be careful when installing the spring! If your not going to use the Hasslers you'll need to return the perches to their correct position. Bolts are available from for Lang's.
