Are 26 & 27 roadster doors all the same? I have a 26 roadster and It appears that the doors that came with my project are 27 based on the door latches. I am having a difficult time fitting the doors.
Thank you
Bill
26/27 Roadster Doors
Topic author - Posts: 184
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Re: 26/27 Roadster Doors
I don’t know but I can send you pictures of the doors from my 26 Roadster if it will help.
- First Name: Arnie
- Last Name: Johansen
Yes there are differences in the roadster doors. The four holes in the inside metal panel are a different size, and the hole for the side curtain rod was changed to eliminate a bushing, and the door latch was changed. Also the hinge mounting area was changed. So in summary yes there were some changes but when I do not know. For instance I have a roadster with one door with big inner panel holes and another with small inner panel holes. Perhaps it came that way or perhaps someone changed a door during its life.
Arnie
Arnie
