Converting Holley NH swivel top to nonswivel NH?
Posted: Mon May 25, 2020 10:41 am
by NealW
Our 21 touring has a Holley NH swivel top carburetor. The carb is in good shape, but since the swivel top was originally for 1925-26 cars with taller firewalls, the adjusting rod makes too large of an angle at the U-joint to go through the shorter 21 firewall, making it very difficult to adjust the mixture while in the car.
Does anyone know if I can convert the carb to a nonswivel version by removing the current swivel spray needle and clamp nut and replacing them with these from Langs?
Adjusting needle clamp nut for Holley NH:
https://www.modeltford.com/item/6208.aspx
NH Spray needle assembly:
https://www.modeltford.com/item/6213.aspx
Thanks,
Neal
Re: Converting Holley NH swivel top to nonswivel NH?
Posted: Mon May 25, 2020 10:49 am
by Original Smith
Do it! An NH will accept either.
Posted: Mon May 25, 2020 11:53 am
by Mark Gregush
Not necessarily, the threads for the spray needle are in the nut for the 25 up NH's. Your carb body may not have threads in it for the earlier spray needle. Check.
Posted: Mon May 25, 2020 12:43 pm
by NealW
Mark,
Here's a picture of the top of my NH carb. The clamp nut threads into the carb body like the nut for nonswivel top. Is this what you were talking about?
thanks,
Neal
Posted: Mon May 25, 2020 12:59 pm
by Mark Gregush
Pull the spray needle and nut to see. The earlier carb clamp nut does not have threads in it like the later one you have. The threads the spray needle screw into in the earlier carbs are in the carb itself, not the nut. Your carb body may have the threads, that is why I said to take a look see.
Posted: Mon May 25, 2020 1:35 pm
by DHort
I never have to adjust either of my carbs in both cars. Wondering why you have to adjust yours so often? You should be able to set it and leave it there. Just trying to save you some hassle.
Posted: Mon May 25, 2020 2:43 pm
by Corey Walker
I’ve never seen one without threads in the carburetor body regardless off which needle was on it. The later needle threads only into the nut and not the body but the threads are still in there or you can make a T top to a swivel top also but you have to replace the needle and nut.
The ones made in 1926 for the cowl mounted tank have a slightly larger float to compensate for added fuel pressure but the bodies are the same.
Posted: Mon May 25, 2020 4:36 pm
by NealW
Before Corey posted this, I took out the needle and nut, and yes, the carb body was threaded...
I don't adjust it much either, but during my first drive in April this year, it was acting like it was running a bit rich and I tried using the knob while driving, but it was really hard to turn, leading to my original reason for the post!
Posted: Mon May 25, 2020 5:10 pm
by NealW
I appreciate the feedback. I may just leave it alone, but I do have a question about the actual installation as it came on the car when I bought it. The picture shows U joint at the top of the carb, but then there's a second U joint to get the adjusting rod around the intake heat pipe, where the rod then goes up to the hole in the metal firewall.
All that zig zagging is what makes it hard to turn from inside the car. Is that how the installation is on a 25-27 car, or is this someone's attempt to make it work on this car?
Thanks,
Neal
Posted: Mon May 25, 2020 5:47 pm
by RajoRacer
Rube Goldgerg attempt ! If you are going to utilize the swivel type adjuster, one needs to also use the later style hot air pipe that has a flattened area for the adjustment rod to clear.
Posted: Mon May 25, 2020 5:49 pm
by RajoRacer
I also see that you stated a '21 BUT it has been updated to a steel firewall - original would have been wood - it sure appears as though the adjuster rod is not coming out of the correct slot for proper alignment !
Posted: Mon May 25, 2020 6:15 pm
by Scott_Conger
Your actual problem is two-fold:
1. the carb stove (heat pipe) is not snuggled up against the exhaust manifold; it is sticking far too far off of it.
2. the kludged double-universal is made to go around it and will never work properly
with the carb stove properly positioned, the correct adjuster sans-swivel will JUST go past the stove (or maybe rub on it, mox nix).
You need to buy:
1. proper needle
2. proper adjuster rod
3. proper needle clamp nut
problem solved and life is good
Posted: Mon May 25, 2020 6:43 pm
by RajoRacer
Here's a quick hot air pipe 101 - I'm not the encyclopedia so let's remember that - far left is around 1912 + /note the crimped edges, next is '13 to later teens, 3rd is into the later teens w/old style clamps, 4th is new style clamps (mounted in reverse of original) - note mount and last is new style clamp AND swivel adjuster - just my own observation. I have close-ups if any interest.
Posted: Mon May 25, 2020 6:55 pm
by Scott_Conger
I'll add one more thing to my post, and that is that I suspect that your hot air pipe is a reproduction. Every reproduction pipe should come equipped with a set of tin-snips, because it needs it. Without significant massaging with tin-snips, every reproduction hot air pipe fits exactly like yours does right now.
Posted: Mon May 25, 2020 7:02 pm
by RajoRacer
Astute observation on Scott's part & to add to Scott's post - all repros I've seen have an open mounting point - originals were closed like shown below on the left.
Posted: Mon May 25, 2020 7:35 pm
by NealW
Steve,
The heat pipe on our 21 is the circled one in the picture below. It does not have an opening, so perhaps is original make from years ago. The unknown installer or restorer apparently decided to add a second U joint to get around it. Regarding the steel firewall, they were available in 1923? and were backwards compatible for post 1916 cars. I'm glad that the car has one, as it seems more durable than a plywood one.
Scott is correct that the holes in the repro ones, at least the one that I installed on our 15 restoration, needed reworking to get the hole opened enough some to allow the clamp to fit correctly.
I may just order a new heat pipe with a hole when I get a needle, clamp nut and new rod and at least make it correct for the year. Having it work better would be nice too!
Posted: Mon May 25, 2020 9:11 pm
by TRDxB2
Scott_Conger wrote: ↑Mon May 25, 2020 6:15 pm
Easy to see what your saying the fix is
Posted: Tue May 26, 2020 5:04 pm
by DanTreace
August 1925
- IMG_3504 (573x580).jpg (112.88 KiB) Viewed 7831 times
The new adjustment needs the correct heat pipe, with a recess to allow the rod to clear.
That is the way of the Improved Car, but sure is nice to use the combo rod on early Ts, esp. when you add a starter, so dash choke is handy, did that 'upgrade' to the Faux '09 runabout.
- Engine compartment (2).jpg (190.36 KiB) Viewed 7831 times
Posted: Sat May 30, 2020 7:33 pm
by NealW
My new heat pipe, mixture rod, nonswivel needle and nut came in the mail today, so time to swap out the parts. As expected, I needed to do some filing on the hole in the heat pipe to get the exhaust clamp to fit. I also needed to slot the hole in my firewall a bit more to get the triangle shaped end of the rod to fit through.
One thing that surprised me a bit was how much my mixture setting changed. I initially set the needle to about the same as the one I removed, but I had a hard time starting it and keeping it running well. It was too lean, requiring about 1/4 more turn rich for it to idle and run well. The shape of the needle was apparently different.
Anyway, I can now finally adjust the mixture from inside of the car, and the car is now set up correctly for its year.
Posted: Sun May 31, 2020 10:52 am
by Scott_Conger
Congratulations, Neal. Job well done.
I sure wish the repro adjusting rods were made correctly with the correct size handle, don't you?
In retrospect, isn't it pretty funny all the trouble the last guy went to to solve that problem?
Posted: Sun May 31, 2020 1:25 pm
by NealW
Yes it would be nice if the handle was the right size, but I had read that they were too wide, so I expected to do the rework.
Who knows why the original restorer did it that way. I didn't know any better when I first got this T. I was a bit surprised how bad it worked, not realizing that it wasn't how "Henry" really made it!
It is interesting to see the cost cutting measures Ford did over the years. The one piece bent mixture rod compared to the mixture rod with a separate brass knob on our 15 runabout.
Posted: Wed Sep 23, 2020 11:32 am
by Original Smith
Take a look in a '26-7 parts book under late carburetor adjusting rods. I believe there are seven different lengths! I think the one on my 1925 is 23".
