26 gas tank
Posted: Fri May 29, 2020 11:24 pm
I found in my stash,2 26-7 fuel tanks. 1 is kinda crappy inside,the other clean as a pin inside but it has a couple rust spots from the outside in that I would need to weld up. I am going to try to send my little camera on a wire down in it this weekend and make sure it is as nice inside out of sight as it is in sight.
IF it needs cleaning and lineing,does it have to come apart because of the baffles?
I am thinking of using it on my speedster if possiable as my seat and so forth are going to make the battery a bit of a problem to get to with a gas tank sitting over it.
