ultra black gasket maker plus gasket?
Topic author - Posts: 229
- First Name: Robert
- Last Name: Thompson
Hello. I recently replaced my Transmission bands and I am not happy with the oil leaks now. I own two model ts and I am very aware about them marking their spot. My question is--Should I use the side gaskets with ultra black gasket maker or just the ultra black alone? I plan on using the front felt seal and the rear round gasket. my main leaks were at the pan ears. Thanks, bobt
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: ultra black gasket maker plus gasket?
The leaks COULD be coming from the rivets securing the c.c. ears - best wipe all oil down then re-start the engine and LOOK closely !
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Check that the pan gasket surface at the pan ears has not bent downward. I just had to remove my freshly rebuilt engine because I had a major oil leak at the passenger side pan ear. I missed the pan being bent down about an 1/8 inch. My pan was tested on my pan jig, and a flashlight, as well as a feeler gauge inserted from the inside, showed the pan was OK. But because the gasket surface lip was bent down, there was no support for the gasket. My leak was a stream the size of a pencil. I had no trouble seeing it .
- Last Name: Kelly
I don't use the felt seal but do use the side gaskets with Ultra-Black. I use a bead of Ultra-Black in place of the felt. I also wipe the gasket surfaces with oil to leave a slight film so the parts will come apart.
