Question on generator
Topic author - Posts: 336
- First Name: Charles
- Last Name: Jenkins
- * REQUIRED* Type and Year of Model Ts owned: Coupe
- MTFCA Number: 28066
My car shows no charge when running will discharge when you turn the lights on before you ask I've tried two different generators two different cutouts the gauge is new and all new wiring I went over all the wiring three different times and it is correct according to the diagram this is the third one that I've wired and never had this problem any ideas
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Question on generator
Can you verify any "output" on either generator ? Normally, if one bench tests the generator with the 3rd brush up, it should motor which "most of the time", will generate power. Ron Patterson is the guy to answer ALL generator questions !
Having said "wiring is correct according to the diagram" but you didn't say that you checked continuity of the wire from the cutout to the ammeter. Its doubtful that its a generator or cutout issue since you have tried different onesCharles J wrote: ↑Mon Jun 01, 2020 12:56 pm.. tried two different generators two different cutouts the gauge is new and all new wiring I went over all the wiring three different times and it is correct according to the diagram this is the third one that I've wired and never had this problem any ideas
- First Name: Ronald
- Last Name: Patterson
Charles
I will be home all day tomorrow.
Give me a call and I will try to help you.
Give me a call after 11am EST-859-881-1677.
Ron Patterson
Ron Patterson
Found the problem after help from Ron Patterson checked out the wiring it was okay so on to the generator that was it just installed a rebuilt one ready to go now thanks for all the help MTFCA Charlie
