Anderson Timer
Posted: Mon Jun 01, 2020 4:08 pm
by Dennis_Brown
Looking thru some old timers I noticed the Anderson Timer has a smaller diameter circle for the contacts. What does the roller assembly look like that attached to the cam compared to other roller assemblies?
Re: Anderson Timer
Posted: Mon Jun 01, 2020 5:46 pm
by A Whiteman
Anderson timers use a 'flapper' rather than a roller. The flapper swipes across the contact spot in the timer instead of 'rolling' or 'rubbing' around the edge as regular timers with rollers or brushes do.
It seems you either like them or you don't. I like them and have had good running experience (i.e. no problems, always work, last a long time).
Anderson flapper:
- T_3221_TSB.jpg (12.44 KiB) Viewed 3201 times
Roller:
- T_3165_BR.jpg (12.97 KiB) Viewed 3200 times
Brush:
- T_3221_B.jpg (9.18 KiB) Viewed 3200 times
Re: Fronty head
Posted: Mon Jun 01, 2020 8:03 pm
by Rjackson
Is there a group of guys that have parts and just talk or is there a club where I can talk to these guys that run frontys
Re: Anderson Timer
Posted: Tue Jun 02, 2020 11:46 pm
by ModelTMark
I have an original Anderson timer with all the company patient data embossed that Frank Fenton rebuilt for me like 15 years ago, and it works like a champ. Frank was reproducing the Anderson Timer back when he and I were on the MTFCI board of directors.
Re: Anderson Timer
Posted: Wed Jun 03, 2020 12:27 am
by MKossor
Dennis, a more recent approach is a Vane actuator used by the I-Timer. Rather than a roller, flapper or brush; the 4 magnets tell the Timer which coil to activate and the windows cut in the outer diameter tell the timer when to activate the coil without any physical contact so its maintenance free and never wears out. A single sensor is used to detect window openings so the Vane actuator is immune to timing cover misalignment about the CAM (concentricity) to minimize coil to coil timing variations.
- I-Timer Vane Actuator.JPG (20.03 KiB) Viewed 2958 times
