Overhead head gasket measurements
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
MTFCA Number: 26904
Post by Chad_Marcheese » Wed Jun 03, 2020 5:31 pm
Hoping someone has a overhead head gasket (that would fit an 8 valve head such as a Fronty or Rajo). I am hoping you can measure the bore size and thickness for me. It really would help if you have a used gasket as it's already squished, but I've got a good idea of what the difference would be if you only have a new one.
Fronty head gasket.jpg (27.15 KiB) Viewed 3275 times
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Overhead head gasket measurements
Post by Henry K. Lee » Wed Jun 03, 2020 5:36 pm
Chad what are you up against? Over bored or over size valves?
Hank
Chad_Marcheese
First Name: Chad
MTFCA Number: 26904
Post by Chad_Marcheese » Wed Jun 03, 2020 5:45 pm
I'm just trying to accurately measure for compression ratio. I don't have a head gasket in my possession at this time. This is information I'd like to pass to my camshaft builder doing a custom grind.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Jun 03, 2020 6:00 pm
I’ve got a handful of new and used flatly gaskets here (steel, copper, and comp)... all start bout .080”-.090”, and crush to bout .050”-.060”
Chad_Marcheese
First Name: Chad
MTFCA Number: 26904
Post by Chad_Marcheese » Wed Jun 03, 2020 6:34 pm
Thats great Kevin! Thank You ----whats the bore diameter on them?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Jun 03, 2020 6:47 pm
Chad my bores (not crushed) are at 3.850” on a copper gasket.
Hank
Hap_Tucker
First Name: Hap
Last Name: Tucker
MTFCA Number: 100
Post by Hap_Tucker » Wed Jun 03, 2020 7:00 pm
Chad,
If you check the Tulsa Model T Ford Club page titled "Head Design" at: http://mtfctulsa.com/Tech/head_design.htm It describes one method of determining the compression ratio of Model T Ford Flat heads.
I'm still a novice at this -- but from memory -- it is not the bore of the head gasket but the bore and stroke of the engine; thickness of the head gasket, and size of the cylinder head chamber that impact the compression ratio. I.e. a stock engine will have a lower compression than if you pull the head bore it .060 over and install the .060 pistons and assemble it back in the same stock configuration otherwise. And yes, if you have a large over bore on the cylinder, you have to have a large enough opening (bore) in the gasket for the piston to clear (in a T where the piston sticks up above the surface of the block).
The Tulsa sight has some other good information on engines see their Tech page at: http://mtfctulsa.com/Tech/index.htm And good luck with your project.
Respectfully submitted,
Hap l9l5 cut off
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Jun 03, 2020 7:12 pm
The head gasket adds volume to the combustion chamber and needs to be accounted for in any CR calculations. A 3.875 bore overhead gasket is about 0.73 cubic inches, while a stock flathead gasket is pretty close to 1.09 cubic inches.
for conversion 1 cubic inch = 16.39cc
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Jun 03, 2020 7:29 pm
Should say flatty... damn auto correct! :roll:
So no diameters from these gaskets
Chad_Marcheese
First Name: Chad
MTFCA Number: 26904
Post by Chad_Marcheese » Wed Jun 03, 2020 7:53 pm
You guys are awesome as usual. That is the info I needed to continue on my calculations. Thank You very much.
Hap, bore and stroke, as well as head chamber size, piston - or + volume, and head gasket volume are all needed to accurately calculate compression. Most are satisfied with assumptions and previous data, but the potential for every engine to be different is there. Especially if you start looking at piston to deck height clearances. It's always nice to know the real numbers...I'm an engine guy so I geek out on info like that.
