I want one.......
Posted: Tue Feb 12, 2019 2:41 pm
by TonyB
I was looking thru the instructions on how to post pictures and found this.
Now that would be GREAT on the front of the Speedster, I want one
There are a couple of things about it that look a little odd. It seems to have an eight cylinder distributor, a water pump and an oil pump. Wow that would be fun but would the water pump get me banned from various speedster run?
- Accessory front cover plate.
Re: I want one.......
Posted: Tue Feb 12, 2019 3:50 pm
I run a similar odd 8 plug distributor ! ZOOM - ZOOM !
When is the tour, Tony ?
Posted: Tue Feb 12, 2019 5:41 pm
by walber
Tony, You would need to check with the event organizer or the posted rules for any of the speedster events. Some have been strict about no post '27 equipment in the past but may be more flexible now. Rules do vary some between the various groups as is their privilege. At one time in at least one group that distributor would not have been permitted but the water pump would have been as that appears to be an appropriate T era accessory front cover.
Posted: Tue Feb 12, 2019 5:44 pm
by walber
On second observation, the distributor on your photo might actually be early enough to qualify. My first look had me thinking it was a Nissan part like Steve and others have.
Posted: Tue Feb 12, 2019 9:00 pm
by babychadwick
It's a period front plate and totally allowed as far as I know. Now good luck finding one . . .
Posted: Wed Feb 13, 2019 7:18 am
by mcenhillk
RajoRacer wrote: ↑Tue Feb 12, 2019 3:50 pm
I like the NASA sticker on a Model T!
Posted: Wed Feb 13, 2019 10:00 am
by babychadwick
For those wondering it is a green plate, more information can be found here.
http://www.mtfca.com/discus/messages/82 ... 1545458635
Posted: Wed Feb 13, 2019 10:02 am
by John Codman
The first T that I soloed in had a VW distributor. My T has a magneto as God and Henry Ford intended.
Posted: Sun Feb 17, 2019 2:36 pm
by Mike Penserini
This Green Engineering triple plate is a NOS era accessory. The distributor is a Delco Studebaker reworked to fire 2 plugs at once. Complete triple plates are a hard item to find, Green Engineering equipment is darn near impossible.
Posted: Sun Feb 17, 2019 3:27 pm
by rbishop26
Tony,
The water pump would probably get you banned from the Model T Club!
Posted: Sun Feb 17, 2019 8:26 pm
by Les Schubert
I see the Nissan cap is referred to, and that is currently a readily available option. I adapted one to a Bosch front plate distributor. A viable way to fire dual plugs using this cap is a coil for a two cylinder Onan engine. It fires both plugs every time in its original application and seems to work ok firing the Nissan dual plug distributor cap
Posted: Sun Feb 17, 2019 8:27 pm
by Les Schubert
The cap and rotor adapter was not difficult to make
