1915 Firewall bracket: Correct fasteners?
Posted: Tue Jun 09, 2020 11:01 pm
What goes here?
I suspect a nut sitting down in a recess where you have trouble getting a wrench on it may not be correct.
Re: 1915 Firewall bracket: Correct fasteners?
Posted: Wed Jun 10, 2020 6:14 am
Steve, my recollection is the nuts do go on top as you show. I could be wrong. If the depth of the machining around the hole is a concern, put a spring washer under the nut. You have plenty of length to still be able to insert a split pin.
Posted: Wed Jun 10, 2020 11:09 am
The nut in the picture above is for the radiator. If you put the bolt in upside down, how are you going to fit the hood board?
Posted: Wed Jun 10, 2020 4:45 pm
by Rich Eagle
I have always done it that way with the nut topside. I don't know why. If it wasn't right someone would have called you on it back here:
http://www.mtfca.com/discus/messages/41 ... 1394896234
Posted: Wed Jun 10, 2020 6:02 pm
by Kerry
Although mine is Canadian, the nut is on the inside of the frame rail and the hood board partly covers the bolt head.
Posted: Wed Jun 10, 2020 6:14 pm
Were there castle nuts that were a little taller? It would need to be a nut that’s tall enough yet be a good tight fit and be able put in a cotter key. The nut that’s on in the pic would need a washer under it to have a good fit and have the cotter pin hole inline with he nut groove and not be to low. But that’s to much perfection to be expected I guess.
Posted: Wed Jun 10, 2020 6:33 pm
This very original '15 body was at Chickasha a few years ago...
Sure seems that the nut is under the frame, as there would be interference with the hood former if the castle nut was above.
Posted: Wed Jun 10, 2020 7:19 pm
by CudaMan
Note how Steve's original bracket is spot faced at the bolt hole so that the bolt head sits flat. The current reproduction brackets that I have seen don't have the spot facing.
