Engine Cradle v. Engine Stand
Posted: Mon Jun 15, 2020 5:25 pm
by paddy1998
As a result of the seized head bolt follies of the past week (
viewtopic.php?f=2&t=13537 I'm going to have to pull the engine.
Because this is the first time I'll be doing this I'll need to acquire some equipment, specifically an engine stand or cradle.
It is unlikely I will ever pull the engine out of any other car besides a Model T.
I'm going to put in new valves, clean up the top, maybe a new fan bearing, and possibly a new clutch spring and clutch discs.
I'm partial to the cradle because of the space limitations of my garage, but will I have sufficient access to remove the clutch spring and drive plate to inspect the clutch discs and lug shoes (1926) while it's still in the crankcase? Seems like not, but I don't know.
Any thoughts would be appreciated.
Re: Engine Cradle v. Engine Stand
Posted: Mon Jun 15, 2020 6:38 pm
by Humblej
A conventional engine stand that rotates is best. It will permit working on the top, the bottom, and turning it on its nose to set the mag ring gap.
Posted: Mon Jun 15, 2020 11:27 pm
by frontyboy
Lang's sell an adapter for a inexpensive motor stand that is designed to fit a model t motor. This will allow you to rotate your motor 360 degrees for ease in working on it.
frontyboy
Posted: Tue Jun 16, 2020 1:10 am
by Altair
I made a wood engine cradle that was designed so that I could turn the engine over and place it in upside down. I would put it on the floor and gingerly turn it over and pick it up replace it upside down. This is not as convenient as a fancy engine stand but it only takes a few minutes longer, and you are never in a hurry working on an engine, slow and methodical gets the job done right.
Posted: Tue Jun 16, 2020 1:32 am
Yes, you want the pan off when you work on the transmission. You also want the stand to rotate so you can turn the engine nose down to work on the transmission and magneto.
Posted: Tue Jun 16, 2020 6:02 am
by Kaiser
One of these will work best for your needs, together with Lang's adapterplate you have the best combination.
Be sure to get the version with four casters, the three wheeled version in not stable enough for the big lump of a T engine and trans.
Added bonus: it can be taken apart for storage if space is a problem.
As usual i have no connection to the seller, the picture is just for illustrative purposes..
Posted: Thu Jun 18, 2020 12:13 am
by paddy1998
Hey thanks for all the advice.
I picked up a used Harbor Freight 1,000 lb stand for cheap from somebody that just wanted it gone and ordered the adapter plate.
Now keeping an eye out for a hoist while I wait for the adapter plate to arrive.
Posted: Thu Jun 18, 2020 11:41 pm
by kelly mt
I really like this engine stand. Very stable. As far as cradle I use three jack stands.
- IMG_2686scrop.jpg (56.53 KiB) Viewed 5882 times
Posted: Fri Jun 19, 2020 1:06 am
by Duey_C
Nice score on the used stand Scott.
Pat, cute 12-20? in the background.
