Reconnecting wishbone problem.
22centerdoor
First Name: David
Last Name: Stauffacher
MTFCA Number: 31
Post by 22centerdoor » Tue Jun 16, 2020 8:39 am
I just adjusted my rod beatings. I removed the inspection cover on a 4-dip pan which necessitated disconnecting the wishbone ball socket. When putting it all back together, the ball socket does not line up with the pan. It is about 3/8 of an inch off. Is this normal? Is there some type of trick to get the wishbone and pan to align? Thanks.
MWalker
Last Name: Walker
MTFCA Number: 314
Re: Reconnecting wishbone problem.
Post by MWalker » Tue Jun 16, 2020 8:41 am
Lift it up using a floor jack and it should slip into place.
John iaccino
Last Name: Iaccino
MTFCA Number: 17802
Post by John iaccino » Tue Jun 16, 2020 8:50 am
Try connecting the front and rear axles together with a ratchet strap. Tighten the strap and it should slip right in.
