Oil weight
MWalker
Last Name: Walker
MTFCA Number: 314
Oil weight
Post by MWalker » Tue Jun 16, 2020 4:33 pm
No, this isn’t a “what kind of oil should I use?” post. I use Pennzoil 10w-30. I have some jugs of 5w-20 which I bought to use in a modern Mercury that I later sold. If I mix the two, will I have 7.5w-25, or doesn’t it work that way?
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Oil weight
Post by CudaMan » Tue Jun 16, 2020 4:48 pm
If they're both the same brand (and probably even if they're not), your theory about mixing them is probably correct. I do it all the time if I end up with some "orphan" oil. It goes into the jug that eventually ends up in the Model T. So far, no harm no foul. :)
MWalker
Last Name: Walker
MTFCA Number: 314
Re: Oil weight
Post by MWalker » Tue Jun 16, 2020 5:12 pm
Yes, they both are Pennzoil. I hate to throw out 2 or 3 5-quart jugs of oil
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
MTFCA Number: 29713
MTFCI Number: 24052
Re: Oil weight
Post by tiredfarmer » Tue Jun 16, 2020 5:49 pm
I was told by my dear ole Dad, never mix oil. Why I never asked, I figured that he was older and new why.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Oil weight
Post by R.V.Anderson » Tue Jun 16, 2020 8:59 pm
I've heard that it's because different brands of oil have possibly incompatible additives that react and cause them to permanently leach out of the oil, leaving a separated portion (up to 1/3) that has no lubricating qualities whatever. I have never confirmed this with a petroleum engineer but that's what I've heard.
Wayfarer
First Name: Cory
Last Name: Woerth
* REQUIRED* Type and Year of Model Ts owned: 26 engine on a stand, Canadian '23 center door
Re: Oil weight
Post by Wayfarer » Tue Jun 16, 2020 9:25 pm
my understanding is that all oils rated by the SAE are required to be mixable
MTFCA Number: 16175
MTFCI Number: 14758
Re: Oil weight
Post by Steve Jelf » Tue Jun 16, 2020 11:46 pm
A very expert Model T mechanic told me he uses 15W-40. Another, who probably drives more than the rest of us combined, uses Kendall 20W-50. (I don't know why Kendall.) Ford recommended 20W. But 5W-20 is NOT the same as 20W. I would definitely not mix in the 5W-20 at 50/50. Maybe half a quart at each oil change, if any at all.
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
MTFCA Number: 16688
MTFCI Number: 19356
Re: Oil weight
Post by HalSched » Wed Jun 17, 2020 12:09 am
I don't know what this has to do with anything, but when I was a kid I used drain oil from a fleet of farm tractors and trucks. I drove the T a lot too. I don't think any of the farm vehicles had oil filters and as I recall the oil was VERY black.
Re: Oil weight
Post by TRDxB2 » Wed Jun 17, 2020 1:25 am
extracted this info from this site https://mechanics.stackexchange.com/que ... -viscosity ( was posted on it in NOV 2018)
From the Chevron.com site: "Can I mix different viscosity grades of motor oils?" "Yes. It is always advisable to not mix motor oil brands, however, different viscosity grades of the same brand motor oil are compatible. Be aware that mixing viscosity grades will turn out a product that is different in viscosity than either what was originally in the engine or what was added."
From Shell.ca: "If you mix viscosity grades such as a 5W30 low-viscosity oil and a 10W40 higher-viscosity oil, it is reasonable to expect that the resulting product will have viscosity characteristics which are thicker than the 5W30, but thinner than the 10W40. This change does not reflect incompatibility - it's simply a re-balancing of the viscosity characteristics. In all other ways, the product should work as expected. But there's absolutely no danger about incompatibility resulting from mixing engine oils," Miller says. "We've tested all of our grades and brands, and we haven't observed any problems."
From Mobil1.com: "For our customers to choose a viscosity grade, we recommend they follow the engine manufacturer's recommendations as indicated in their owner's manual. There is no need to mix two Mobil 1 viscosity grades when one will do; however, we see no problem mixing different SAE grades of Mobil 1 Tri-Synthetic series motor oils."
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Oil weight
Post by D Stroud » Wed Jun 17, 2020 6:28 am
As for a T, I doubt it would care much at all if was mixed, as long as there was some kind oil in the crankcase. ;) ;) Dave
1925 mostly original coupe.
MTFCA Number: 16175
MTFCI Number: 14758
Re: Oil weight
Post by Steve Jelf » Wed Jun 17, 2020 8:41 am
...as long as there was some kind oil in the crankcase.
Or passing through the crankcase on its way to the floor.
MWalker
Last Name: Walker
MTFCA Number: 314
Re: Oil weight
Post by MWalker » Wed Jun 17, 2020 8:51 am
Thanks to everyone for your input. I especially like Frank Brandi's post, which seems to have quite a bit of factual and helpful information.
Bud Delong
First Name: Kenneth
Last Name: DeLong
Re: Oil weight
Post by Bud Delong » Wed Jun 17, 2020 9:01 am
Is there any written proof that Henry said anything other than a light weight high grade machinery oil. In 1955 when many of Ford people of the times were still with us the book Tin Lizzie by Stern said SAE-10. Then as today much depended on where you lived and the temp and season.Oil is cheap,engines not so much!!!! Bud. :D
Squirrel
First Name: Jim
Last Name: Forbes
Re: Oil weight
Post by Squirrel » Wed Jun 17, 2020 9:10 am
Pictures of old oil cans. Draw your own conclusions.
23ford
First Name: Warren
Last Name: Webb
Re: Oil weight
Post by 23ford » Wed Jun 17, 2020 7:43 pm
We need Rich Chillingworth to comment on all this as he is a petrol eingeer....just sayin :mrgreen:
MWalker
Last Name: Walker
MTFCA Number: 314
Re: Oil weight
Post by MWalker » Thu Jun 18, 2020 8:56 am
I see a post by "Squirrel" above. I recognize you from the HAMB; surprised to see you here. :)
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Re: Oil weight
Post by J1MGOLDEN » Mon Jun 22, 2020 5:45 pm
When you get that all figured out, the can markings, grading and contents are soon all going to change again.
I read someplace that the early engine oil was not much thicker than kerosene or automatic transmission fluid.
That would not work well today, as any drip is frowned on!
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Re: Oil weight
Post by ModelTWoods » Mon Jun 22, 2020 6:15 pm
No not oil weight : Oil type ! I've read discussion on the forum where using Shell Rotella 15W-40 diesel oil was discussed. Any merit to it?
Bud Delong
First Name: Kenneth
Last Name: DeLong
Re: Oil weight
Post by Bud Delong » Mon Jun 22, 2020 6:30 pm
I use a lot of Rotella 15-40 in many engines but not in our stem wind model T"s :D Bud.
