TT Upholstery
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
TT Upholstery
Post by Jeepbone1 » Sat Jun 20, 2020 1:59 am
My classtique upholstery kit came in yesterday and my uncle and I spent most of yesterday installing it. Fantastic product and Mike has some of the best customer service skills I’ve ever seen. It did take four months to get it but it was well worth the wait. I now have a new found hate for hog rings. I could live the rest of my life without ever seeing another one and be completely ok! I haven’t seen much as restoration documentation for the closed cab trucks so here’s hoping I can help out the next guy.
Brad
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Re: TT Upholstery
Post by Jeepbone1 » Sat Jun 20, 2020 2:01 am
More pictures
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Re: TT Upholstery
Post by Jeepbone1 » Sat Jun 20, 2020 2:05 am
More pictures
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Re: TT Upholstery
Post by Jeepbone1 » Sat Jun 20, 2020 2:06 am
More pictures
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Re: TT Upholstery
Post by Jeepbone1 » Sat Jun 20, 2020 2:07 am
10 characters blah blah
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: TT Upholstery
Post by Adam » Sat Jun 20, 2020 9:17 am
That definitely works, but originally there were no hog rings or plywood involved. There is a “V” channel at the base of the cushions and back springs that gets pried open. There should be cording welt sewn into the seat covers on the sides that just gets pinched in those channels to fasten the covers to the springs. Real simple and easy to install.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Re: TT Upholstery
Post by Duey_C » Sat Jun 20, 2020 12:13 pm
I have a file somewhere bout the TT's. Info is a bit limited.
Brad, would you show a close-up pic or two of "hanging" the rear cushion up on the back wall? Thank you.
Looks great!
Andy Loso
First Name: Andy
Last Name: Loso
MTFCA Number: 346
MTFCI Number: 119
Re: TT Upholstery
Post by Andy Loso » Sat Jun 20, 2020 10:47 pm
Duey,
Come on over and I can show you on ours. If my camera phone wasn't broken I'd pop a few photos.
Andy
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Re: TT Upholstery
Post by Duey_C » Sun Jun 21, 2020 12:02 am
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Re: TT Upholstery
Post by Jeepbone1 » Sun Jun 21, 2020 12:10 am
Duey, it doesn’t hang persay. It has four support “rods” two on top and two on the bottom. The two on top slide into slots made between the top and bottom panel seams. The two on the bottom are held in by bolts through the bottom panel. These are the best pictures I can get. The truck is too black and shiny to get great pictures. Woe is me, right? I used 1/4”-20 brass slotted machine screws, so it won’t rust, with rubber washers against the panel then stainless washers and lock washers to make sure it doesn’t come apart. I also used stainless square nuts to keep it more period correct. Hope this helps.
Brad
