Is this safe to run?
Topic author - Posts: 154
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
I put a new fan blade on and the flange crumbled in my hand.. what remained seamed strong. My question is do u think this will last a while yet ?
- Last Name: Rutt
Re: Is this safe to run?
Whoops I need to add the pic[image][/image]
- Last Name: Rutt
Wow try this again
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
Without seeing it,I would say it is not.Remember that fan is going to try to drill a BIG hole in your radiator if it gets loose.
- Last Name: Rutt
[image][/image]Ok I'm struggling here
- Last Name: Rutt
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
No, run without a fan until you can find a replacement, they are plentiful and cheap. Unless you are in a parade or stuck in a traffic jam, you do not really need a fan.
https://www.modeltford.com/item/3004E.aspx
15% the price of a new radiator, or equivalent to 4 1/2 fill-ups in PA.
piece of mind: priceless
NH Full Flow Float Valves
- Last Name: Rutt
Ok.. thanks
- First Name: Jeff
- Last Name: Humble
Larry, while you are in there you should re-route your timer wiring harness up to the water outlet and back. Use an adell clamp at the water outlet bolt to hold it just like Henry did.
- MTFCA Number: 52564
Wondering too about the routing of the timer wire harness? The 26/27 with coil box on the motor would have had a short harness that ran from the box over the engine down the passenger side to the timer. Cars and trucks with firewall mounted coil boxes, the timer harness would have been all on the passenger side along the frame rail. With it running along the front like that and loose, potential to cut with fan belt or? If it is the correct 26/27 harness, move it so it goes over the top of the water outlet. There would have been a wire clip that held it using the passenger side water outlet bolt.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 28924
Running without a fan is only as good as your radiator.
- MTFCA Number: 14972
- MTFCI Number: 15411
Are you referring to the aluminum fan hub flange that crumbled ?
Adjuster, but the pulley does look a little wonky, could be the angle.
1920 Dodge touring
1920 Dodge touring
Thanks Mark - and, I had my glasses on !
Larry - I have some of those eccentrics around here if you want to replace it.
Larry - I sent you an email w/photo - check your junk mail foder.
"Folder" !!!
- First Name: Harold
- Last Name: Schwendeman
- MTFCA Number: 0
....it's O.K. Steve,....sometimes dar's foder in dem' folders!
- Last Name: Rutt
Sorry my email changed... try... larryrutt7at gmail.com
