Height of Rands or Metzger Windshield
Topic author - Posts: 451
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Would someone post the height and width of either a Rands or Metzger Windshield on a 1909-10 Touring as well as each of the two parts of the windshield? Also, the height of the riser board above the firewall. Thanks alot
- Last Name: hughes
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring (#2438)
Re: Height of Rands or Metzger Windshield
My 1909 Touring has a "MEZGER" windscreen. The upper (folding) part of which, measures 41 1/4 inches in width, and 11 inches in height, The lower (non-folding) section measures 41 1/4 inches in width, and 16 3/4 inches in height. At it's widest point the wood riser board (It fits between the top of the dash, and the bottom of the screen), is 35 inches. Feel free to contact me if you require any other details. I hope this helps.
- Last Name: hughes
On the inside front-cover of the Jan/Feb 2020 issue of the Horseless Carriage Gazette there is a reprint in full-colour and in full-size, of an original advertisement, which extols the finer points of "Mezger" windscreens. It clearly shows how the hinge and support mechanism of these screens functions.
- Last Name: Snell
Thank you John. So the overall height of the Metzger is 27 3/4" by 41 wide. How high is the riser?
- First Name: Tom
- Last Name: Rootlieb
- MTFCA Number: 440
Merger windshield measurements. The filler board was furnished by the windshield company and varied. I don’t have my car here, but as best I recall it is 4-5” tall.
- Last Name: Snell
Great thanks for the dimensions of the Metzger. Can someone now post the size of a Rands for 1909-10? Thanks
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
Windshield height is 25.5, width is 41.25. Filler board is 4.75.
- Last Name: Snell
Thanks Kim, is that a roll down windshield I see above the Rands?
- First Name: Kim
Yes, it's original to the car. My car was delivered with both the rands and a roll up windshield.
