Universal joint pin length
Posted: Sun Jun 28, 2020 4:04 pm
by DHort
I was attempting to install the universal joint on the drive shaft. The pins I have are 1 11/32" and the universal joint is 1 3/8", so they are too short to peen them. Is my universal joint too wide or are the pins too short? What length should they be?
Re: Universal joint pin length
Posted: Sun Jun 28, 2020 4:31 pm
by John.Zibell
Don't have one handy to measure, but Lang's has them for $0.25 https://www.modeltford.com/item/2574.aspx
Posted: Mon Jun 29, 2020 12:09 am
by DHort
I think the ones I have are from Langs and that is part of why I am confused.
Posted: Mon Jun 29, 2020 3:55 am
by D Stroud
Dave, maybe make your own pin? Is your u-joint Ford script or aftermarket? I'm sure if you do a bit of research, you can find what is needed. JMHO Dave
Posted: Mon Jun 29, 2020 9:06 am
by rondupree
Like several other applications on the T that pin is made from an odd size wire gauge that is not readily available.
Posted: Mon Jun 29, 2020 9:42 am
Measures .275” x 1.5”
Odd size dia. Close to 9/32” but tad less, and Parts Books list it as 1.5” length but error on dia., as given to be 3/32” but that is clearly wrong :o
