Making progress on the TT
Topic author - Posts: 86
- Last Name: Jones
I'm still waiting for the Amish Wheel guy to get my wheel finished. It's taken longer than expected.
I got the bed put on and I'm going to round up some stake pockets and make a stake bed.
I got the floor boards put in. I'm going have to change the angle of the front floor board to get a little more pedal extension.
I'm getting better at crank starting it, I got it started on the 3rd pull the other day. That is a world record.
Next is the seat, windshield, walls and roof of the cab......
Re: Making progress on the TT
Good for you
a word of caution: ensure that the slope of the floorboard is not so steep as to limit the natural full travel of low pedal and brake (and reverse), and that the slots in the floor board will not limit same. IE, if pedals hit floorboard necessitating tightening the bands too much to activate in a short throw, then the bands may drag and at best will make crank starting harder and at worst will cause overheating and potential drum/transmission damage.
Good luck!
Good luck!
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Petrino
How come only one wheel? Was it damaged?
Looking very good!!
Looking very good!!
- Last Name: Jones
Ya, I'm going to have to modify / change the angle of the front floor board to get a little more pedal extension.
Those are sold rear tires and the felloe was loose on one of the rims. The wheel guy thought that the felloe rotted on the bottom part of the wheel where it was parked for a number of years. He was going to make new / steam bend up an new felloe for me. Said he broke off a spoke tenon or two in the process.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Scott, its looking good. I see you have extra room built in the cab behind the tank for your long legs. Good idea. Mine is not made for tall people. Steeringwheel to back of cab is not great. My belly is not huge but putting a backrest in my cab will be a challenge not to be up against the wheel. Getting the floorboard around the peddles is a challenge with no pattern. Been there, redone that.
- Last Name: Jones
Dallas,
Ya, after sitting in yours I wanted to make mine a little larger in both width and length. Heck, I don't think I could even drive your little pickup with my 6'3" 230 lb frame.....
- Last Name: Nunn
- MTFCA Number: 50321
Scott, when I made new floorboards for my '26 Runabout I measured the angle of the floorboard supports in the body. It measured exactly 30 degrees. I don't know for certain but I suspect that TT floorboards would have the same angle since pedal geometry is the same.
- Last Name: Jones
Initially, I wasn't sure of the angle as as I eyeballed it and found that it was too much. Now that I'm inside and after doing a little math / trigonometry I found I had 7" of rise and 10" of run which gave me a 35 degree angle (too much). Next go round 'm shooting for 6" of rise and 10" of run, which would give me 30 degrees. Too funny...Mark Nunn wrote: ↑Tue Jun 30, 2020 8:26 amScott, when I made new floorboards for my '26 Runabout I measured the angle of the floorboard supports in the body. It measured exactly 30 degrees. I don't know for certain but I suspect that TT floorboards would have the same angle since pedal geometry is the same.
- Last Name: Nunn
30 degrees and a 10" run has a rise of close to 5 3/4".
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Looking good Scott.
You and Dallas make me want a TT....and I know where there's a brilliant one with a gorgeous bed on it. My wife would kill me if another old car followed me home though.
1924 Touring
Better to ask forgiveness than permission Don!
- First Name: Don
- Last Name: Allen
True. She is a very forgiving sort.....have to be to put up with the absent-minded professor all these years.
Although I'm asking myself why I'd need another slow-moving, 100 year old vehicle.
1924 Touring
Why? To have fun and poison the minds of others that cant believe that it runs and its drivable anywhere.
- First Name: Don
- Last Name: Allen
Dallas Landers wrote: ↑Tue Jun 30, 2020 2:28 pmWhy? To have fun and poison the minds of others that cant believe that it runs and its drivable anywhere.
1924 Touring
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Itchin' for more Scott.
Ya, these T's can be a bit snug for us taller guys.
Looks great!
Looks great!
- First Name: Don
- Last Name: Allen
So true. My future son-in-law was here the other day. He's 5' 7" and skinny. My daughter is 5' 2" and also thin.
They wanted to take the T around the block a few times. Both of them hopped up in the T easy as pie....they fit in that front seat together with lots of room and he wasn't cramped behind the wheel at all.
I couldn't help but think that it was people of this size for whom the T's were designed.
I'm 6' and although I've been heavy for a while, I'm the rapidly shrinking man with my new way of eating. However, even when I'm back to my military weight (170), I think I'll still be a bit cramped behind the wheel of a T.
1924 Touring
