What is the material used for the "ground" electrode on Champion"X", or other plugs?
Topic author - Posts: 6435
Kind of a stretch to ask here, but I know that there is an amazing breadth of industrial experience lurking out there in Forum-land. So, does anyone know what the bent wire that is, or likely is, that is staked into the threaded plug on "X" plugs? I have my suspicions, but no longer have acces to a SEM or other analytic equipment, so need some industry knowledge/guidance.
Thank you in advance
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: What is the material used for the "ground" electrode on Firestone "X", or other plugs?
Scott I had the book with all that data in it up to 5 years ago. Loaned it to a guy, and he denies that he had it! Wonder why! Books do not leave this place no more! Wish I could have been of help.
No problem Hank
I bet that frosts your flakes, though.
FOUND what I need
FOUND what I need
- MTFCA Number: 16175
- MTFCI Number: 14758
You mean Champion X?
Steve, Yes, of course. Thank you and I will fix the heading.
I was changing tires yesterday and had "Firestone" on the brain, I guess.
thanks again.
thanks again.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: What is the material used for the "ground" electrode on Champion"X", or other plugs?
Damn geriatrics pixies, always playing when you ask them nicely not too!
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
"FOUND what I need "
Wahtja find sir?
Wahtja find sir?
