Unusual Drive Shaft Universal Joint Housing
jeffstag
First Name: Jeff
Last Name: Versteeg
* REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Post by jeffstag » Wed Jul 01, 2020 5:11 pm
How often do you see a brass one of these?
23 Touring
23 Fordor
25 TT
27 TT
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Re: Unusual Drive Shaft Universal Joint Housing
Post by A Whiteman » Wed Jul 01, 2020 6:24 pm
Probably made of Bronze (copper and tin) which is much harder and stronger than brass (copper and zinc), although different metals can be used in bronze such as aluminium and manganese and even a bit of zinc too. Brass is used in lamps and fittings in the T and is quite soft and malleable.
(Bronze castings are used in some Ruckstell gears and in TT crown wheels too).
Even so, it would seem uncommon to find a bronze one of these, although I have 2 bronze universal joints in my parts bin too. Would these be very early ones?
Post by Scott_Conger » Wed Jul 01, 2020 7:09 pm
I'm not ready to believe it's bronze. Throw a magnet on it.
NH Full Flow Float Valves
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Wed Jul 01, 2020 8:55 pm
I have one, definitely bronze or brass
Post by Scott_Conger » Wed Jul 01, 2020 9:20 pm
well, I'm not to old to learn something new. Thanks.
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Wed Jul 01, 2020 10:11 pm
It's probably bronze, but you can't tell with a magnet, since bronze and brass are both non-magnetic. The bronze universal joints has me intrigued, though. Somebody at Ford was tinkering around.
23 Touring
23 Fordor
25 TT
27 TT
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Wed Jul 01, 2020 10:16 pm
Check those universal joints that are bronze next to a Model T one. If they are not the same as the T one they could be NRS Ford ones. I think the NRS ones are a little bigger maybe. I would be interested in them if they are.
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Post by bobt » Thu Jul 02, 2020 5:36 am
Did you try a magnet? Post reply.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Jul 02, 2020 9:32 am
I've seen one or two of those. Pretty neat. I wonder if Ford ever made a two piece one?
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Thu Jul 02, 2020 10:32 am
Curiously, aluminum bronze is magnetic. How about that ?
"Get a horse !"
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Thu Jul 02, 2020 10:46 am
This is not magnetic at all. When it came to me it was painted and covered in grime just like normal, but there was a scratch that looked unusually shiney, so I stuck a magnet on it and it didn't stick.
23 Touring
23 Fordor
25 TT
27 TT
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jul 02, 2020 7:33 pm
I don't know about very early T's, but the NRS cars had bronze U-Joints.
As to the subject bronze torque tube ball, I have never seen such a thing!
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jul 02, 2020 7:35 pm
Jeff,
I assume it has the Ford logo cast on it?
Post by Allan » Thu Jul 02, 2020 7:39 pm
Jeff, does it have a separate babbit bush for the driveshaft or does the shaft run directly in the bronze housing?
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jul 02, 2020 10:06 pm
So could the ball joint be an N/R/S fitting too?
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Thu Jul 02, 2020 10:28 pm
Jerry, I don’t see the Ford logo stamp, but it does have the correct part number T7608
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Thu Jul 02, 2020 10:31 pm
Allan, it looks like it has a steel bushing in there, it’s still a little dirty down there because I didn’t bother to go that far down with the sand blaster
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Thu Jul 02, 2020 10:36 pm
Adrian, This wouldn't be NRS since it's the later style. I'm assuming Pre-Model T would be something similar to the early two-piece end.
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Thu Jul 02, 2020 10:40 pm
Jerry, I'll have to amend my earlier reply. I found the Ford stamp, it was just faint.
23 Touring
23 Fordor
25 TT
27 TT
Post by Allan » Thu Jul 02, 2020 11:22 pm
So it wasn't made in bronze so they could delete the bushing. I can't see any other reason to go to a casting of material which is more expensive.
Alln fron down under.
pre15dale
First Name: Dale
Last Name: Kemmerer
Post by pre15dale » Fri Jul 03, 2020 11:05 am
Mine has the Ford script which if I understand correctly that the script on parts began about 1919 would make fairly late in production. Min has part number T7609
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
MTFCA Number: 1575
Post by FATMAN » Fri Jul 03, 2020 12:09 pm
How about this piece?
Bob
Luxford
First Name: Peter
Last Name: Kable
* REQUIRED* Type and Year of Model Ts owned: 1911 Town Car 1913 Speedster 1915 kampcar
MTFCA Number: 4
Post by Luxford » Fri Jul 03, 2020 7:23 pm
This housing ticks all the boxes for being a Universal Joint housing for the Ford marine engine.
A housing without any tailshaft in bronze, check out the marine motor post
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Fri Jul 03, 2020 10:07 pm
Interesting....Not saying you're wrong, but weren't those 3rd party conversions? Would marine conversion parts still carry Ford part numbers?
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
First Name: Jeff
Last Name: Versteeg
Post by jeffstag » Fri Jul 03, 2020 10:09 pm
The piece that Robert posted is 3rd party, so that may have been some kind of conversion, just brainstorming
23 Touring
23 Fordor
25 TT
27 TT
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Jul 04, 2020 6:23 am
In the third picture the marking on the part says "National", so I guess it is third party.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Jul 04, 2020 8:39 am
A couple of Model T parts that were bronze for years are sediment bulbs and Holley G carburetors. I believe the change of both to cast iron was a cost saving measure.
