Unusual Drive Shaft Universal Joint Housing
Topic author - Posts: 133
- First Name: Jeff
- Last Name: Versteeg
- * REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
How often do you see a brass one of these?
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Adrian
- Last Name: Whiteman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Re: Unusual Drive Shaft Universal Joint Housing
Probably made of Bronze (copper and tin) which is much harder and stronger than brass (copper and zinc), although different metals can be used in bronze such as aluminium and manganese and even a bit of zinc too. Brass is used in lamps and fittings in the T and is quite soft and malleable.
(Bronze castings are used in some Ruckstell gears and in TT crown wheels too).
Even so, it would seem uncommon to find a bronze one of these, although I have 2 bronze universal joints in my parts bin too. Would these be very early ones?
I'm not ready to believe it's bronze. Throw a magnet on it.
NH Full Flow Float Valves
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I have one, definitely bronze or brass
well, I'm not to old to learn something new. Thanks.
- First Name: Jeff
It's probably bronze, but you can't tell with a magnet, since bronze and brass are both non-magnetic. The bronze universal joints has me intrigued, though. Somebody at Ford was tinkering around.
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Herb
- Last Name: Iffrig
Check those universal joints that are bronze next to a Model T one. If they are not the same as the T one they could be NRS Ford ones. I think the NRS ones are a little bigger maybe. I would be interested in them if they are.
- First Name: Robert
- Last Name: Thompson
Did you try a magnet? Post reply.
- MTFCA Number: 121
- MTFCI Number: 16310
I've seen one or two of those. Pretty neat. I wonder if Ford ever made a two piece one?
- First Name: Rich
- Last Name: Bingham
Curiously, aluminum bronze is magnetic. How about that ?
"Get a horse !"
- First Name: Jeff
This is not magnetic at all. When it came to me it was painted and covered in grime just like normal, but there was a scratch that looked unusually shiney, so I stuck a magnet on it and it didn't stick.
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- MTFCA Number: 24868
A Whiteman wrote: ↑Wed Jul 01, 2020 6:24 pmProbably made of Bronze (copper and tin) which is much harder and stronger than brass (copper and zinc), although different metals can be used in bronze such as aluminium and manganese and even a bit of zinc too. Brass is used in lamps and fittings in the T and is quite soft and malleable.
I don't know about very early T's, but the NRS cars had bronze U-Joints.
As to the subject bronze torque tube ball, I have never seen such a thing!
Jeff,
I assume it has the Ford logo cast on it?
Jeff, does it have a separate babbit bush for the driveshaft or does the shaft run directly in the bronze housing?
So could the ball joint be an N/R/S fitting too?I don't know about very early T's, but the NRS cars had bronze U-Joints.
- First Name: Jeff
Jerry, I don’t see the Ford logo stamp, but it does have the correct part number T7608
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Jeff
Allan, it looks like it has a steel bushing in there, it’s still a little dirty down there because I didn’t bother to go that far down with the sand blaster
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Jeff
Adrian, This wouldn't be NRS since it's the later style. I'm assuming Pre-Model T would be something similar to the early two-piece end.
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Jeff
Jerry, I'll have to amend my earlier reply. I found the Ford stamp, it was just faint.
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
So it wasn't made in bronze so they could delete the bushing. I can't see any other reason to go to a casting of material which is more expensive.
Alln fron down under.
- First Name: Dale
Mine has the Ford script which if I understand correctly that the script on parts began about 1919 would make fairly late in production. Min has part number T7609
- First Name: Peter
- Last Name: Kable
- MTFCA Number: 4
This housing ticks all the boxes for being a Universal Joint housing for the Ford marine engine.
A housing without any tailshaft in bronze, check out the marine motor post
- First Name: Jeff
Interesting....Not saying you're wrong, but weren't those 3rd party conversions? Would marine conversion parts still carry Ford part numbers?
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
- First Name: Jeff
The piece that Robert posted is 3rd party, so that may have been some kind of conversion, just brainstorming
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
In the third picture the marking on the part says "National", so I guess it is third party.The piece that Robert posted is 3rd party, so that may have been some kind of conversion, just brainstorming
- MTFCA Number: 16175
- MTFCI Number: 14758
A couple of Model T parts that were bronze for years are sediment bulbs and Holley G carburetors. I believe the change of both to cast iron was a cost saving measure.
