Modifying Rear Spare Carrier
Topic author - Posts: 53
- First Name: Lee
- Last Name: Mitchell
I cannot find a Rear Spare Carrier for a '24 Roadster with 21" Split Rims. Had a thought this weekend and decided to ask before heading down this road. Would it be possible to use a Carrier for 30" rims and modify it for 21? Would that be blasphemy?
Lee
Lee
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
- MTFCI Number: 13377
Re: Modifying Rear Spare Carrier
The arms that come from the frame out to the carrier are made quite different. Where they reach the ring, they are dipped in to make them narrower. Advertise for what you need and have patience.
- MTFCA Number: 28924
Seems like there would be a 21” spare tire carrier somewhere. They do show up from time to time for sale. It’s up to you if you want to cut a 30” down but be patient. What usually happens when your looking for a certain part you can’t ever find it. But when you don’t need it that’s when it shows up and usually more than one! Did you try Model t Haven or FordBarn T parts? Good luck.
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
If you want to stay, "Ford", but can stand a little lack of authenicity, why not use a 26-27 touring/sedan gooseneck carrier with the 21" demountable rim "Y"?
- First Name: Lee
Thanks for the input guys. I will abandon the modification idea and keep looking for the correct mount.
- MTFCA Number: 121
- MTFCI Number: 16310
They are out there, and by the way, a 1925 will work. Just ask Jim Rodell.
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Lee,
I modified a 30" to hold a 21" on the rear of my 26/27 many years ago. If you would like photos, I can be reached at kimrwynn@gmail.com.
Kim R. Wynn
Kim R. Wynn
- Last Name: Hatch
- MTFCA Number: 49974
Lee check your email. Dan
- First Name: Dennis
- Last Name: Prince
- MTFCA Number: 22802
This is how I modified a 30x3 1/2 carrier to except a 21 in spare and it can be reversed if you want to.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I have a 24 coupe for my next project. The spare tire carrier has been hacked off for some reason. I have both pieces and cannot figure why they done it. I will check into the possibility someone tried to modify another carrier. Cannot get to it right now.
- First Name: Lee
I finally found one. It is in the mail to me now.
