Dayton wire wheel info
Posted: Fri Feb 15, 2019 1:50 am
by Nv Bob
How do you remove the hub cotter keys? The keys rear and front they seem way down inside the hubs
Bob
Re: Dayton wire wheel info
Posted: Fri Feb 15, 2019 6:42 am
by E THOMAS
On Rudge spline drive hubs, there is usually a small hole in the side, sometimes covered with a small screw.
Posted: Fri Feb 15, 2019 12:03 pm
by Nv Bob
These are 6 pin drive 30x3.5 there is no hole or screw in the hub
Posted: Fri Feb 15, 2019 12:39 pm
by Kevin Pharis
The Buffalo hubs have the same condition...
Use a little tool, and a lotta patience!
Posted: Fri Feb 15, 2019 1:37 pm
by Dan McEachern
Add a 1/4" diameter thru hole in the hub that lines up with the keyway and the cotter pin hole in the axle. The added hole won't weaken the hub. Or do as Kevin suggested and just live with it. Needle nose pliers are your friend.
Posted: Fri Feb 15, 2019 3:54 pm
Yes - LONG needle nose !!!
Posted: Fri Feb 15, 2019 10:58 pm
by Nv Bob
Thanks im going mark it and once off drill
Thanks guys
