Help!! Taillight bracket failure - Something doesn't seem right...
Posted: Fri Jul 10, 2020 7:50 pm
I was putting the remainng boards on my garage floor project (looks amazing), and noticed the taillight bracket had lost (as I found out later, stripped) out one of the screws holding it to the body wood, leaving the license plate, stoplight, and license plate at a precarious angle. OK, normally, I wouldn't be too concerned - easy enough to do an epoxied dowel plug and reinstall...
Except then something hit me. On the bracket, there are 3 holes, in a triangle, for 3 screws to support the taillight / license plate bracket, as is normal for a '15 body. Right so far? Except when I started to line stuff up, I realized the "top" hole of the triangle (the one frontmost on the car) isn't anywhere near any of the wood under that part of the car.
What am I missing? Did someone rewood the back half of the body at some time in the past and use the wrong sized piece? Is that 3rd hole supposed to go into the sheet metal under the back seat? Did the eastbound train from Chicago pass the westbound train out of San Francisco and no one noticed?
I hate the thought of tearing apart the otherwise unmolested sheetmetal on the tail end of the car; I can see that becoming a domino of a disaster... but at this stage I'm not sure either what I'm missing or what someone else missed...
Anyone else ever run into this? I'm thinking maybe building an L beacket to go from the front of the wood to where the top hole is...
