Making a gas gauge for a cowl tank
Posted: Mon Jul 13, 2020 2:48 pm
by Squirrel
Since I've been driving my 27 coupe around more, including a trip to Tombstone this morning, I decided I need to start checking the fuel level occasionally. I haven't had much luck with the paint stick method. I tried a few other things, and decided that it needs to have a nice porous but high contrast surface, and also have a way to prevent me dropping it in the tank, plus it needs to stay vertical, which helps always go to the same depth. I looked at pictures of a bunch of others, and this is what I ended up making. It's all brand new, but the idea was to make it like it could have been made it a long time ago.
Time will tell how well it works. I think there's enough reserve capacity built into my measurements, to keep me safe. I like to fill up most cars around 1/4 tank, anyways. Note the slot at the bottom end....multi purpose tool.
Re: Making a gas gauge for a cowl tank
Posted: Mon Jul 13, 2020 7:47 pm
by Susanne
The stick works because the gasoline discolors the wood at the level of the fuel while its wet with gas... I've done it with regular sticks off a forest floor.
If the stick is sealed, then it won't work, which may be your problem. People put clear lacquer on gas sticks to "preserve the markings" but it prevents the stick from working.
You can always get a yardstick at like Lowes or Home Despot and cut one from that - Just DON'T coat or paint it.
Posted: Mon Jul 13, 2020 8:57 pm
by Squirrel
I tried a couple different bare wood paint sticks, as well as some other things. The best results I got were with rusty steel! so that's what I used. It's easy to see the gas level with it.
Thanks for the suggestions! I guess a real stick, would work best. But this one kept me busy for half an hour making it, so I can't complain.
Posted: Tue Jul 14, 2020 9:07 am
by John.Zibell
Lang's has them back in stock for all tank types. I asked for one with my last parts order and one arrived.
Posted: Tue Jul 14, 2020 9:58 am
Posted: Tue Jul 14, 2020 10:09 am
by Squirrel
Thanks for all the suggestions. The cowl tank is a bit different than the under seat tanks, which led to my strange, long list of requirements...which my gauge meets, but none of the others do. The tank shape lets you put the gauge in at an angle, which you don't want to do, and also it's in an awkward place.
Squirrel wrote: ↑Mon Jul 13, 2020 2:48 pm
Like I said, time will tell how well mine works.
Posted: Tue Jul 14, 2020 10:17 pm
by Mustang1964s
One of our senior club members ran out of gas.
He check the level. Looked at the discolor of the stick.
The stick had been used for so many years it was permanently discolored.
Another member brought over a new stick and sure enough the tank was empty.
Needless to say. He received the new stick as a present.
The old stick went on the wall.
The sticks are plentiful and are usually free.
But, if the club stops at a gas station, I top off. Even if I put in 50 cents.
I have run out of gas once too often.
Posted: Tue Jul 14, 2020 11:01 pm
by Squirrel
That does sound like the best plan. I've run out of gas many times in my life, with a working gas gauge...but lately, never in a car that does not have a working gauge. I guess complacency can be a problem!
Posted: Tue Jul 14, 2020 11:52 pm
I use the traditional wood stick with Ford markings, but I gave it a coat of polyurethane and scuffed it with sandpaper so the wet part shows up.
Whatever you use for a gauge, I highly recommend these. They have saved me an unscheduled long walk more than once.
Posted: Wed Jul 15, 2020 10:17 am
Steve —on your tank stick I’m assuming that the square tank reading would be for the 26-27 cowl tanks? The earlier square tanks in the early Coupes had a square tank. Just wondering.
I have a tank stick but it has oval and round tank markings only.
Posted: Wed Jul 15, 2020 10:33 am
I don't know, John. I assumed it was 26-27, but maybe both tanks measure the same.
Posted: Wed Jul 15, 2020 11:09 am
by Susanne
Steve Jelf wrote: ↑Tue Jul 14, 2020 11:52 pm
Boyco cans are worth their weight!
I'm wondering what I should put in the blue one - Water, 50/50, waterless coolant, or ?? I worry it may someday rust out and then I'll have to rely on my desert bags...
Posted: Wed Jul 15, 2020 1:29 pm
by Mark Nunn
John kuehn wrote: ↑Wed Jul 15, 2020 10:17 am
The square markings are not for the cowl tank. The gallon markings are too evenly spaced. The cowl tanks have graduated markings due to their odd shape.
Posted: Wed Jul 15, 2020 11:25 pm
by jab35
John: refer to Ken's post in:
http://www.mtfca.com/discus/messages/25 ... 1346263614
By Ken Kopsky, Lytle TX on Friday, August 10, 2012 - 06:07 pm:
It really isn't Rocket Science. If you're so inclined to get up from your PC, you can make one.
Posted: Wed Jul 15, 2020 11:42 pm
I'd say 50/50 for its anti-rust ingredients.
Posted: Wed Jul 15, 2020 11:56 pm
by hah
Looked at jab35 post referencing another post....the stick looks like the markings of a dox cup.
Posted: Thu Jul 16, 2020 6:00 pm
by Les Schubert
When I saw the title of the thread I was thinking this!!
Posted: Thu Jul 16, 2020 6:08 pm
by Susanne
Les Schubert wrote: ↑Thu Jul 16, 2020 6:00 pm
Me too... It's like the one on my space heater for my shop. And it works!
Orrrrrrrr.... one of those that have the spiral-ey insert that goes down into the tank... not sure how that would work on an improved car, but I'm sure where there's a will, there's a way!
Ya know, I wonder how well the old cork floats handle modern "gasoline"... would it be better to switch it to something like Nitrile, or maybe make one out of brass sheet...
Posted: Thu Jul 16, 2020 7:37 pm
Susanne - I have several original gas gauges in cars and I've replace the original cork floats with the Model A gas gauge modern material float - they work perfect BUT I only run "clear" gas in my T's !
