Can arc welding weaken magnets ?
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Jul 14, 2020 2:41 am
I am wondering about arc welding(DC) can hurt the magnets. I'm about to do a small repair on the frame close to the engine,
and would like to hear your opinion. Thanks.
Last Name: van Ekeren
Re: Can arc welding weaken magnets ?
Post by Kerry » Tue Jul 14, 2020 3:23 am
Actually it would be around the other way, if welding to close to something that is magnetized, it stuffs up the weld, Called magnetic arc.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Jul 14, 2020 3:40 am
Thanks Frank. I've read about that phenomenon but its about 3 feet from the transmission so I don't think that will be a problem.
I am more concerned with the current flowing thru the frame/engine. But Im maybe overthinking the possible danger of demagnetising . ;)
Post by Kerry » Tue Jul 14, 2020 3:53 am
Just make sure that your earth clamp is next to your weld area and all will be good.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Jul 14, 2020 3:57 am
Thanks. Good advise.
Post by Norman Kling » Tue Jul 14, 2020 10:59 am
I welded up a crack in the frame and put on a reinforcement right at the place where the crankcase ear is bolted to the frame. That was almost 30 years ago and the frame has not cracked again and the magneto still works.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Jul 14, 2020 5:19 pm
Norman, that's a relief to hear. Thank you.
