Overhead valve
RichardW
Last Name: Williamson
* REQUIRED* Type and Year of Model Ts owned: 1913
Overhead valve
Post by RichardW » Fri Jul 17, 2020 12:17 am
Will any overhead valve head fit in 27 coupe without firewall modification?
Richard
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Overhead valve
Post by Dan McEachern » Fri Jul 17, 2020 1:12 am
There is a version of a B Rajo where the back of the head is sloped to clear a 26/27 firewall.
Kerry
Last Name: van Ekeren
Re: Overhead valve
Post by Kerry » Fri Jul 17, 2020 4:19 am
Rajo's fit but the rocker cover is modified for the 26/7 fire wall. But the problem I found was they stink of oil fumes being open at the back of the rocker cover, removed my 4 valve for that reason.
old_charley
First Name: Bryan
Last Name: Ostergren
* REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
MTFCA Number: 8082
Re: Overhead valve
Post by old_charley » Fri Jul 17, 2020 10:44 am
Rajo also made the Model C35 to fit the '26 cowl without cutting into it. I have one, and the rear of the cover doesn't fit well enough to seal worth a darn.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Re: Overhead valve
Post by TonyB » Fri Jul 17, 2020 12:27 pm
I thought the four valve Rajo Model A was designed specifically to fit a standard firewall. The Four valve A will give you a much power as you need, they are plenty fast from my experience. JMHO
Tony Bowker
La Mesa, California
