Why is one drive shaft slightly longer than the other?
Topic author - Posts: 914
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
Pictured are 2 drive shafts exactly aligned at the pinion gear end. One is noticeably longer than the other. Which one is right for a 1925 motor with a 1926-27 differential? The longer one came off of my Touring parts salad car of unknown history when I first took it a part and had all kinds of bizarre hacks on it to make it work. The second one came from a trusted source.
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Why is one drive shaft slightly longer than the other?
Years ago John Regan was disgusted with the drive shafts being sold at the time, and started supplying new ones correctly made to the Ford prints. If you're a better Google searcher than I am you might find his forum posts explaining the difference. The parts book shows the same DS for all years 1911-1927. Ditto Lang's catalogue.
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Ignacio, The shorter trusted one looks more correct. Check your U joint on the shafts to see if the U joint pin hole matches up. I think the longer shaft will stick out into the joint area of the U joint Look on the shafts for Ford logo on the U joint area flats.
- Last Name: Valdes
Bingo the U-joint did not fit on the end of the longer shaft from an unknown source at all. It fit perfectly on the shorter one from a known source.
kmatt2 wrote: ↑Fri Jul 17, 2020 3:48 amIgnacio, The shorter trusted one looks more correct. Check your U joint on the shafts to see if the U joint pin hole matches up. I think the longer shaft will stick out into the joint area of the U joint Look on the shafts for Ford logo on the U joint area flats.
