A dumb question about TT tires
Posted: Fri Jul 17, 2020 9:23 pm
Howdy all,
So I've gone and bought a pair of 5.00x23 tires for the rear axle of my 1925 TT project, which *I think* are correct for the 23" split rims I have. For the front axle, I used the turnbuckle trick in the mounting bosses to "pull in" on the rim, but the rear rims have no bosses through which I could run a turnbuckle... By hand, I can't quite get the rim squeezed in enough to fit through the tire. Is there a trick here that I'm missing? The rim would go if I could get it pinched down just that *little* bit more, but I'm not sure how I can get it any further on my own...
Thanks in advance!
- Brett
Thanks in advance!
- Brett
