Back of body sitting crooked
Posted: Fri Jul 17, 2020 10:44 pm
by Rosenfelder
I finally got the driveshaft and differential fixed (I think). When I lowered the body on to the rear spring, It was very hard to see if the spring center bolt went into the hole in the frame cross member. Now one side of the body ('27 touring) sits a couple inches higher than the other. Question: How do you get the body centered on the spring? Thanks, J.R.
Re: Back of body sitting crooked
Posted: Fri Jul 17, 2020 11:48 pm
John, you have the problem half solved already, realising what the cause is. If you can't see the centre bolt in the frame hole, can you feel it? Once that is correct, it is a matter of tightening the U bolts correctly. Take them up a bit at a time and check the body height as you go. The camber in the road will often make the passenger side appear lower, when in fact it may not be.
Hope this helps.
Posted: Sat Jul 18, 2020 5:31 am
by Dallas Landers
The 27 Tudor Im working on leened 1 1/2 inches. They left the plates for U bolts out when the gooseneck tire carrier was installed which ment the rear spring was loose in the frame. I installed the plates and carrier and problem solved.
Posted: Sat Jul 18, 2020 7:49 am
by Alan Long
I have just been through this exact issue with a Model T. The Owner fitted another rear spring to rectify the LHS of the body
being lower than the RHS by 1 1/2” .after the work, no change occurred.
I would suggest that you park the vehicle on level ground, wheels pointed straight ahead and all tyres inflated to the same pressure.Then give the body a rock from side to side.
Then measure the height of the chassis from the ground at the same point on both sides. If this is vastly different then your issue is as mentioned previously being the Spring or U Bolt tightening procedure.
If the Chassis is sitting level (like just rectified) you then need to check the body height from the ground.
Also, if your trying to fix a different height of the rear mudguards it maybe the body or the arms supporting the guards.
Should be rectified easily once you know where the issue is!
Alan
Posted: Sat Jul 18, 2020 8:00 am
by Tmooreheadf
I had the same issue recently after rebuilding and lubing the rear springs. The issue wound up being the sides of the springs were tight in the crossmember, causing it to cock and never seating all the way un. A little grinding on the sides of the springs allowed the spring to slide into the crossmember easily. A little paint. Problem solved.
Posted: Sat Jul 18, 2020 8:22 am
by Alan Long
Tom, yep I agree! Some Chassis have the Rivet heads protruding making spring installation a challenge!
Alan
Posted: Sat Jul 18, 2020 10:14 am
by Rosenfelder
My car has a spare tire carrier. Before I took it apart for the drive line rebuild, the body was level. It didn't have plates on the cross-member to spring u-clips. Can I loosen the retaining nuts and jump on the running board to shift the body on to the spring center bolt? Do cars with the spare tire carrier also have the retainer plates? Thanks, J.R.
Posted: Sat Jul 18, 2020 10:55 am
Answer to J.R. Yes. A couple things which might not have been mentioned above. There should be a leather or rubber pad between the top of the spring and the frame. And the head of the bolt protrudes through that pad and into a notch in the center of the frame cross member. Then you tighten up the u bolts on each side a bit at a time until tight. If the body sits high on one side, loosen the opposite side just a bit and try to tighten the high side until it is even. Measure on a level surface from the floor to the frame, rather than to the body. It is also possible that sometime in the past someone could have put a higher block or shimmed up the body to frame attachment So also check out the distance from the top of the frame to the bottom rail of the body.
This applies to an open car. When you install the top, be sure to measure the distance between the top of the back body to the top bow. Even though it might not be the same distance from the floor. If the top bow conforms to the body, it will tilt with the body and will look straight as the car is driven, however, if it is measured from the floor, no matter how the body might be tilted the top will always look crooked.
Posted: Sat Jul 18, 2020 9:49 pm
by Rosenfelder
Thanks all. I followed these suggestions, and got the thing level and tight.
Posted: Sat Jul 18, 2020 10:05 pm
by Dallas Landers
Good news John. Thank you for the update. Its nice to have a follow up report.
Posted: Sun Jul 19, 2020 5:23 am
by D Stroud
If springs don't seat in the crossmember correctly, I wouldn't grind the springs to fit. That's just asking for a broken spring later on down the road. Find out what the issue is with the croomember, and fix that! JMHO Dave
