Has anyone found a radiator shop in central Florida that HAS either repaired or re-cored a round tube T radiator for you ?
Yea I know it will cost almost as much as a new one, but I don’t want the old one taking up shelf space.
So far, all shops have turned me down.
Radiator repair in Florida
Topic author - Posts: 233
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor
30 A Rdstr PU
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: Radiator repair in Florida
Ed’s radiator service if you want to try. In Seminole county close to Sanford airport. Does old tractors and such. Don’t let his shop scare you. Good man.
(407) 323-8915
https://maps.google.com/maps?client=saf ... IgAQ%3D%3D
(407) 323-8915
- First Name: Paul
Thanks. Will call him
NP on the garage - Those are usually the good ones !
30 A Rdstr PU
30 A Rdstr PU
You have no idea on the garage until you see or meet Ed. He repaired my old tt radiator and fixed all leaks. I will admit I eventually replaced it with a new one as it just didn’t transfer heat well anymore. I did not ask Ed to core it but maybe I should have. Be patient as will will have to show up and meet him. He did quick work once he looked at it and was not expensive. He doesn’t do volume from what I can tell. Again, just good people. Where is your tt wrecker in CF? TS
- First Name: Paul
We’re about 20 mi west of Clermont.
30 A Rdstr PU
30 A Rdstr PU
little bit of a hike over here then. Maybe it will be worth the trip. let me know if I can help. Good luck. TS
