Radiator repair in Florida
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
MTFCA Number: 27359
Post by PDGx » Sat Feb 16, 2019 11:08 am
Has anyone found a radiator shop in central Florida that HAS either repaired or re-cored a round tube T radiator for you ?
Yea I know it will cost almost as much as a new one, but I don’t want the old one taking up shelf space. :P
So far, all shops have turned me down.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor
One390
* REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: Radiator repair in Florida
Post by One390 » Sat Feb 16, 2019 8:38 pm
Ed’s radiator service if you want to try. In Seminole county close to Sanford airport. Does old tractors and such. Don’t let his shop scare you. Good man.
(407) 323-8915
https://maps.google.com/maps?client=saf ... IgAQ%3D%3D
PDGx
First Name: Paul
MTFCA Number: 27359
Post by PDGx » Sun Feb 17, 2019 6:51 am
Thanks. Will call him
NP on the garage - Those are usually the good ones !
30 A Rdstr PU
One390
Post by One390 » Sun Feb 17, 2019 7:39 am
You have no idea on the garage until you see or meet Ed. He repaired my old tt radiator and fixed all leaks. I will admit I eventually replaced it with a new one as it just didn’t transfer heat well anymore. I did not ask Ed to core it but maybe I should have. Be patient as will will have to show up and meet him. He did quick work once he looked at it and was not expensive. He doesn’t do volume from what I can tell. Again, just good people. Where is your tt wrecker in CF? TS
PDGx
First Name: Paul
MTFCA Number: 27359
Post by PDGx » Sun Feb 17, 2019 7:47 am
We’re about 20 mi west of Clermont.
30 A Rdstr PU
One390
Post by One390 » Sun Feb 17, 2019 5:56 pm
little bit of a hike over here then. Maybe it will be worth the trip. let me know if I can help. Good luck. TS
One390
Post by One390 » Sun Feb 17, 2019 5:57 pm
