Valve Stem
Posted: Wed Jul 22, 2020 8:24 pm
by HalSched
I just had a flat on the R F wheel. Upon opening the tire I found that the brass valve stem broke loose from the inner tube. Can a new stem be attached to the tube?
Re: Valve Stem
Posted: Wed Jul 22, 2020 9:20 pm
by Chris Haynes
That depends on the hole in the tube. If it is not torn you can simply reinstall your valve. If a new tube is needed I highly recommend those made by Blockley,
https://www.blockleytyre.com/product/30x3-5-inner-tube
Re: Valve Stem
Posted: Thu Jul 23, 2020 11:40 am
by jsaylor
Hal, Try a metal valve stem. Steve spells it out here.
http://dauntlessgeezer.com/DG110.html
Re: Valve Stem
Posted: Thu Jul 23, 2020 2:15 pm
by Rich Bingham
The tube shown in the Blockley site has a brass stem.
So far, the 30x3” tires and tubes don’t seem to be available yet.
Re: Valve Stem
Posted: Thu Jul 23, 2020 3:05 pm
by Steve Jelf
I'm sure the metal stem tubes from Blockley are excellent. But I have been buying Hartford tubes, cutting off the rubber stems, and installing my own metal stems. So far they have presented no problems. I intend for my next tyres to be Blockleys, but I will keep the Hartford tubes in them.
