Model Ts
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, 1923 speedster
- MTFCA Number: 52552
Re: Model Ts
Very interesting highly accessoried roadster. Looks like a 1914. Hard to tell, but are the splash sheilds indented to give extra foot room stepping into the car?
- First Name: Kevin
- Last Name: Pharis
Re: Model Ts
And I’m assuming that’s a front mounted electric starter... never seen that style before. Very cool
- First Name: Lee
- Last Name: Mitchell
Re: Model Ts
What is the chain spoke for? Third photo front wheel.
- MTFCA Number: 52564
Re: Model Ts
Speedometer drive gear.
1920 Dodge touring
1920 Dodge touring
- Last Name: Guitar
- Board Member Since: 2012
Re: Model Ts
The building in the second photo:
A few more Wichita photos.
- Last Name: Guitar
Re: Model Ts
I guess the thing on the front of the car in the second photo is part of the Everful Water System.
Last edited by John E. Guitar on Sun Jul 26, 2020 2:43 am, edited 1 time in total.
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Re: Model Ts
That bus is mind-boggling! How does a 20hp drag all that body along, let alone filled with passengers. Imagine if a bunch of kids rushed to grab the back seats - the front wheels would lift off.
Re: Model Ts
The bus is built on a chaindrive extension like a Smiths Form-A-Truck, so it will be very low geared. That will be the key to it being able to haul a load. There is till more of the body forward of the rear axle, so it shouldn't tip up.
I was wondering what year the tourer is in the second photo. At first glance I had it don as a 14 model with the forward folding windscreen, but then I noticed the fore-doors.
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: Model Ts
Allan, I think the bus driver had to be very careful where the students sat, that thing is way back heavy even when empty, unless the body was built extremely light in the rear. JMHO Dave
1925 mostly original coupe.
- MTFCA Number: 24868
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Model Ts
Keep them coming. I love those old photos!
- First Name: Kevin
- Last Name: Pharis
Re: Model Ts
When reading the article on the Everful Water System, it basically describes an overflow tank that also condenses the steam, and most likely siphons the captured overflow back into the radiator similar to modern systems but without pressure. No mention of any mechanism to perform the task.John E. Guitar wrote: ↑Sun Jul 26, 2020 2:39 amI guess the thing on the front of the car in the second photo is part of the Everful Water System.
This roadster has obviously been electrified, and sports accessory headlights and spotlight. Notice the lack of hand crank as well...? Could this not only be an accessory starter... but a starter generator combo unit?
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
- MTFCA Number: 8082
Re: Model Ts
Allan, the T in question looks to be a '12 with a '13 windshield mounted vertically. Note the support rods. they look to be '13 style but mounted more upright on this car than they would be on a '13.
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
Re: Model Ts
on the late 12 the windshield is none ford issue. also check out the headlights.well used ford ha,ha. charley
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Re: Model Ts
The 1912 touri.g in the third picture has N J. 17 license, so it is in pretty good shape for a 5 year old car, must not be driven in the winter.
Topic author - Posts: 2828
- First Name: Tom
- Last Name: Rootlieb
- MTFCA Number: 440
Re: Model Ts
The 12 in picture #3 appears to have a 09-10 type windshield with spring loaded, over center type hinges. The windshield mounting brackets have been changed to the even reach type, and because they are different they are relocated next to the stock location. The 13 style support rods are longer than stock ones to compensate for the vertical windshield. You can see the bolt head just ahead of the upper front door hinge. Also the car has 1915 front fenders. Notice the cross bead on the bottom side and with enlargement you see three flat head type rivets. The front lower trim of the radiator is missing. The headlights are slightly bent upward, with the lower part of the door flattened. Hand crank handle is missing off crank. Tells me someone ran into something and damaged the fenders, windshield, crank, radiator and headlights. Otherwise the car looks pretty clean.
- Last Name: Shaver
Re: Model Ts
one headlight is 12 one is 13.charley
- First Name: Tom
- MTFCA Number: 440
Re: Model Ts
I completely missed that Charley. Also the front fender irons are the eyelet type to hook the top straps to.
