scat crank shaft and rods
Posted: Sun Jul 26, 2020 9:26 pm
by Rich Huggins
Having trouble finding main bearings scat crank 4.25 stroke bearing's are Fm gm 2965 ra ul std. Has scat main caps clam shell bearings, found rod bearings no problem clevite cb 278 p std any help!
Re: scat crank shaft and rods
Posted: Wed Jul 29, 2020 8:02 am
by Rich Huggins
Have found bearings will have them soon! The new scat crank was reground and model a bearing caps bored to except clam shell bearings bearings that are from a mg. A lot of time spent looking for the bearings and stepped beyond my budget this engine was built 2011 has less than 100 miles on it and down due to clearance problems crank hit oil line and pistons kissed the head, scat crank only have babbitt bearings is what i was told by scat
