Quadrant rivets
blgitn
First Name: Roger
Last Name: Harmon
MTFCA Number: 16412
Quadrant rivets
Post by blgitn » Sat Aug 01, 2020 6:10 pm
I'm replacing the spark and gas levers:
I've filed the heads off the bottom side of the quadrant rivets but can't seem to knock them out. Is there a secret to doing this?
Thanks in advance.
R/ Roger.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Quadrant rivets
Post by RajoRacer » Sat Aug 01, 2020 7:29 pm
Most likely a bigger hammer and a real good steel drift - I've always taken the tops off - easier to pound down !
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Re: Quadrant rivets
Post by DanTreace » Sat Aug 01, 2020 7:54 pm
Grind the underside rivet flush, then you can see the circle of the rivet shank.
Center punch the center. Sometimes a twist drill is needed to drill down about 1/4" or so.
Then punch out with drift that will fit into your drilled pilot hole. Lots of times they loosen up with just the center punch. ;)
Of course having the column locked tight in a vise gives solid fixture to apply the hammer, no lost of energy.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Quadrant rivets
Post by RajoRacer » Sat Aug 01, 2020 8:18 pm
You are assuming his column is out of the car !
MTFCA Number: 4838
MTFCI Number: 115
Re: Quadrant rivets
Post by DanTreace » Sat Aug 01, 2020 8:46 pm
Steve, in that case, shore up the column with a 2x4 to the floorboards :?
2nighthawks
First Name: Harold
Last Name: Schwendeman
MTFCA Number: 0
Re: Quadrant rivets
Post by 2nighthawks » Sat Aug 01, 2020 9:08 pm
Hmmm,...either you guys missed something or I did. Roger distinctly said the "QUADRANT" rivets! :)
2nighthawks
First Name: Harold
MTFCA Number: 0
Re: Quadrant rivets
Post by 2nighthawks » Sat Aug 01, 2020 9:11 pm
......but then he also mentioned the spark and gas levers. Maybe he just used the wrong terminology, huh? :?
2nighthawks
First Name: Harold
MTFCA Number: 0
Re: Quadrant rivets
Post by 2nighthawks » Sat Aug 01, 2020 9:17 pm
Well,....I guess it's me that's confused, as I was just reading something about the quadrant that's riveted to the frame for the emergency brake lever pawl to engage,......sorry,.....harold :oops:
Re: Quadrant rivets
Post by Allan » Sun Aug 02, 2020 3:11 am
I'd not like to be changing out control levers with the steering column still in the car! Might be do-able in an open car with the top down, but re-riveting the steering case and the little levers on the control rods would be a real task, even if you could get them off while still in the car.
MTFCA Number: 121
MTFCI Number: 16310
Re: Quadrant rivets
Post by Original Smith » Sun Aug 02, 2020 10:44 am
When I did my '25, I wanted the exact appearance of the original rivets, so I drove the rivets out from the bottom, and had two turned down to the original size. As I recall, I had to bend each rivet slightly to get it to go through the bottom hole.
blgitn
First Name: Roger
Last Name: Harmon
MTFCA Number: 16412
Re: Quadrant rivets
Post by blgitn » Mon Aug 03, 2020 3:59 pm
The column is out of the car.
The heads are ground off the bottoms of the rivits.
I'll try drilling down a little bit.
What's the correct terminology for the notched semi-circle under the steering wheel that controls the motion of the spark and gas levers?
R/ Roger.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Re: Quadrant rivets
Post by Susanne » Mon Aug 03, 2020 4:39 pm
That's the "Quadrant" people refer to...
