Oil line
Posted: Fri Aug 07, 2020 11:37 am
by Bill Thompson
Which hole does the outside oil line use?
Re: Oil line
Posted: Fri Aug 07, 2020 1:17 pm
by George House
Assuming you use the mag post accy outside oil line like I use, it’s the bolt hole immediately to the left of the crankshaft & pully.
Re: Oil line
Posted: Sat Aug 08, 2020 11:29 am
by GrandpaFord
The outside oil line I used required holes to be cut in the hogs head and the side of the pan near the front. I did all the work when the engine was apart for an overhaul. I added the oil line that allows an optional oil filter which has trapped lots of crap. My oil now stays clean. The oil filter that is used is actually one used for a hydraulic system. It does not have the check valve that regular oil filters have. The check valve adds too much restriction so that no oil will flow.
Re: Oil line
Posted: Sat Aug 08, 2020 3:37 pm
by TeveS-Nor Cal
More info on the oil filter, etc. please
Re: Oil line
Posted: Sun Aug 09, 2020 8:40 pm
by NHUSA
Bill, I use the outside oil line that is described by George House.
