pesty skip found
Chuck Stevens
First Name: chuck
Last Name: stevens
pesty skip found
Post by Chuck Stevens » Sat Aug 08, 2020 7:15 am
My 21 roadster has had a skip off and on since I've had it. Yesterday I turned on the ign and hand turned it to each firing point. The garage was dark and I saw a spark in the wrong place, The copper spark plug wire had come loose from the brass end that connects it to the coil. They are soldered originally. A drop of solder and we were back in business. I would have thought the small gap would have no effect on firing the plug. So turn off your lights and see what you see. It made my day, Chuck.
Last Name: Kuehn
MTFCA Number: 28924
Re: pesty skip found
Post by John kuehn » Sat Aug 08, 2020 8:45 am
That’s good that you found it!
The simple fix things are usually the hardest to find sometimes. I’ll bet that’s happened to more than few T’s.
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Sat Aug 08, 2020 1:12 pm
My wife sez I do some of my best work in the dark!!!!!
frontyboy :lol:
