Model T Brake Is Pretty Good
Topic author - Posts: 1554
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Ok...that statement may cause some eyebrows to be raised, but bear with me....
In my build thread (see link below), I talked about how I wasn't adjusting the brake band properly, this was causing the brake to be pretty mushy and insufficient. I drove the car like this for a while and, sadly, got kind of used to it.
https://mtfca.com/phpBB3/viewtopic.php? ... 29#p112929
Once I learned the error of my ways however, I was impressed with how adequate the Model T tranmission brake is when everything is in working order and properly adjusted.
Don't get me wrong, I'm not going to go sliding around any corners or attempting to stop on a dime. I'll still do all the wise things like using engine braking and anticipating stops well in advance, but when following these rules, I find the transmission brake to be very adequate....almost, dare I say, good.
Have I lost my mind?
1924 Touring
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Re: Model T Brake Is Pretty Good
I agree with you Don. I have more issues backing up. The bows are so high I do not see that little car parked behind me. No problem stopping with the cars in front of me, at least the ones that know how to drive.
- First Name: Don
- Last Name: Allen
Yeah...I can see that.
I haven't had top bows on my car since I revived it. As I get closer to the point where I'll be installing the top, I keep wondering about how limited my rear view is going to be. I have a rear view mirror mounted on the center of my windshield frame and I look at it constantly. I find it critical to know who's approaching from the rear and how fast. Without that knowledge, I think I'll be much less confident in my driving.
Since my car is not a restoration, I'm considering adding a roll-up flap in the rear.
1924 Touring
- First Name: Don
- Last Name: Allen
Last year a guy parked a brand new Mustang right behind me. Never saw it. I had to back up. Bang!
A couple of things. It is good to have brakes on the rear wheels even though the transmission brake is working. If you have a failure in the drive train from the U joint to the axle, your wheel brakes will stop the car. I like three sets of brakes on my cars. 1. the transmission brake. 2 the parking brake.
3. the Rocky Mountain brakes or Hydraulic rear wheel brakes. When I apply the Rocky Mountain brakes both the rear wheel brakes and the transmission brake work together and the car stops very well. The parking brake will also apply the Rocky Mountain Brakes when you pull the lever tight.
The other thing is when you are parked, and wish to pull out, it is a good idea with any car, but especially with a T to get out and walk around the car first before you back up. If you are in a car with no door on the drivers side, but have a passenger, ask them to get out and walk around and let you know what is behind you.
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
REAR VIEW CAMERA
They make small wireless back up and bluetooth cameras You can put on the rear of Your car about the size of Your thumb some mount on the license plate frame and You can view the rear of Your car on Your I phone or small screen. even record video of who tailended You while You were eating dinner.
- First Name: Don
- Last Name: Allen
Rocky Mountain Brakes are on the “to-do” list...just not in the budget yet.
1924 Touring
- First Name: Rich
- Last Name: Bingham
The stock Model T “service brake” can lock up the rear wheels on dry pavement when properly adjusted. All else is fail-safe (and reasonably considered). Skidding isn’t stopping.
"Get a horse !"
- MTFCA Number: 28924
If I was going to add brakes to one of my T’s I think I would go with AC brakes. I met the owner at Chickasha a few years ago and checked them out. Probably Rocky Mountain brakes are the most popular but the AC brakes are pretty good too. In my mind they’ve been under the radar for many years. Then there’s disc brakes that came out not to many years ago.
Another topic that’s got different ideas and which is the best. It can get interesting!
I think there are more than kind of AC brakes. On my 26 Roadster I bought a new set of brakes, I think from Chaffin's, but maybe from somewhere else (It was 30 years ago). Anyway, they appear to be the same as the currently sold Rocky Mountain Brakes for the large drum axle. The parts are identical except the logo cast into the yoke which bolts to the rear drum says AC. I have seen some others which are made to fit the small drum axles which are different from Rocky Mountain brakes. They use the original drums. There is an advantage in using larger drums in that it increases the braking power, however the way they are made, they don't work very well in reverse. I have heard that the company now has changed the brake so it works better in reverse than the older ones.
