What Is This Part?
Topic author - Posts: 205
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
What Is This Part?
I got this with some other speedometer parts but have not figured out what it is. I have looked through Russ Furstnow's speedometer book but did not find it.
Is it part of a clamp bracket for mounting a swivel at the wheel?
Thanks for any help you can provide.
(Sorry that the first picture is upside down.)Is it part of a clamp bracket for mounting a swivel at the wheel?
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: What Is This Part?
Most, if not all Stewart speedometer parts had their script imprinted from what I've seen & I'm pretty familiar with Stewart pieces - Russ F. will be able to identify IF it's a speedo piece.
Does the opposite end of the male threaded end have internal threads ?
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
It looks familiar to me, I am thinking it MIGHT be an early Model A King Pin locking bolt. They are different from the later ones (these early pieces are known as "AR" parts from the Ford replacement parts IDs)
BUT this is just a guess from fuzzy memories!
T'ake care,
David Dewey
David Dewey
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet
- MTFCA Number: 28
- MTFCI Number: 10546
It's not a speedometer part. Russ Furstnow
- MTFCA Number: 52564
I think David is on the right track. Could be AA truck.
1920 Dodge touring
1920 Dodge touring
- First Name: James F
- Last Name: Dix
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1921 Coupe
- MTFCA Number: 7082
- MTFCI Number: 14604
Early Model A Kingpin retainer.
Jim Dix
Big Flats, NY
Jim Dix
Big Flats, NY
Thanks for all of the replies. A know very little about Model A parts.
Thanks again.
Thanks again.
- First Name: David
- Last Name: Dewey
Well some of us are "reformed" Model A guys, I still haven't dug out any books though to see if I guessed right. Too busy mudding & taping sheetrock in my living room.
T'ake care,
David Dewey
David Dewey
- Last Name: Page
- MTFCA Number: 28488
- Board Member Since: 2010
Later Model A
- Last Name: Page
Describes all year models.
- First Name: David
- Last Name: Dewey
Ah, there's the documentation needed. So it is "type 2" used in '29 until August--didn't realize it was used that late.
Thanks for solving it!
T'ake care,
David Dewey
David Dewey
