Straight axle questions
Posted: Tue Aug 18, 2020 7:35 am
by Mike Lebsack-Iowa
We are machining a pair of new straight axles and have a couple questions. We have a pair of badly worn originals but would like to verify two things.
1. What width should the key way be? Our original is very worn and wide.
2. What is the relationship of the pin or bolt hole to the keyway? It appears to be roughly 90 degree or has a centerline perpendicular to the centerline of the keyway.
Please private message me or email me at lebsackmike@gmail.com
Re: Straight axle questions
Posted: Tue Aug 18, 2020 8:22 am
by Kerry
maybe of some help, key for the straight axle 1/4x 1/4 x 4-9/16, Bore on the hub 1-1/16 x 4-3/4
Posted: Tue Aug 18, 2020 8:37 am
Thanks Kerry, every little bit helps. Mike
Posted: Tue Aug 18, 2020 9:54 am
by Dan B
