Exhaust leak at nut
Posted: Sun Aug 23, 2020 4:12 pm
by jonathan
Noticed today that exhaust is coming out from under the nut ( between the pipe and nut ) that connects the manifold to the pipe. The nut is tight. What can I do?
Re: Exhaust leak at nut
Posted: Sun Aug 23, 2020 4:37 pm
by Adam
There are some repro brass nuts that have been available off and on over the years that aren’t quite machined just right. The threads and/or clearance inside isn’t quite deep enough and the pipe flange doesn’t get tight against the manifold.
If this is the case, you need a better quality exhaust nut.
Posted: Sun Aug 23, 2020 5:15 pm
by jonathan
It turns out the flare at the end of the pipe was broken off! Ordered a new pipe from Lang’s.
Posted: Sun Aug 23, 2020 9:08 pm
Jonathan, that sometimes happens when the flange does not contact the manifold correctly, and the nut is done up tightly to close the gap. This puts stress on both the pipe flange and the manifold. The flange needs to sit neatly on the manifold before the nut is done up.
Allan from down under
Posted: Mon Aug 24, 2020 2:07 am
by Robert Kiefaber
I use 0000 steel wool as packing inside nut. Seals very well.
