Battery charging from the magneto
Topic author - Posts: 44
- First Name: Ron
- Last Name: Jackson
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
- MTFCA Number: 5880
- MTFCI Number: 5880
- Board Member Since: 2014
They have had a charger that could be wired to your mag post to charge a 6 or 12 volt battery. No one has them any more. Does anybody know where to get one. I am looking for one that will charge a 12 battery. Thanks
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Re: Battery charging from the magneto
If you can't find one ready made, you could make your own.
http://www.mtfca.com/discus/messages/41 ... 1416288062
- MTFCA Number: 16175
- MTFCI Number: 14758
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Ron, Have you contacted John Regan. He recently just made up a perfect solution and location to mount it and had them available?
His latest design is the best of all and is most simple to connect to the bat and mag posts. Check it out
1912 Torpedo Roadster
- Attachments
- HSBC2.jpg (41.74 KiB) Viewed 1928 times
Looks like I copied John, but without the green base.
- First Name: Ron
How would I find this John Regan do you have his phone number or email thanks, Ron
Ron, go to Extra Quick Links at the top of this page and click on Find a Member.
Entering his first and last name should get you the contact info.
- First Name: Gene
Ron, If you look back up to the picture of Johns charger there is a link to another discussion. If you go there and scroll down to the bottom you'll see a post from John. It's easiest to contact a p[oster when you simply click on their name and you can send them a note directly.
- First Name: Ron
Again I would like to thank all you guys for your help. I have found the charger I need thanks to John Regan
