Battery charging from the magneto
Posted: Wed Aug 26, 2020 6:18 pm
by Rjackson
They have had a charger that could be wired to your mag post to charge a 6 or 12 volt battery. No one has them any more. Does anybody know where to get one. I am looking for one that will charge a 12 battery. Thanks
Re: Battery charging from the magneto
Posted: Wed Aug 26, 2020 6:31 pm
by CudaMan
If you can't find one ready made, you could make your own.
http://www.mtfca.com/discus/messages/41 ... 1416288062
Posted: Wed Aug 26, 2020 11:29 pm
by Steve Jelf
Posted: Thu Aug 27, 2020 12:44 am
by SurfCityGene
Ron, Have you contacted John Regan. He recently just made up a perfect solution and location to mount it and had them available?
His latest design is the best of all and is most simple to connect to the bat and mag posts. Check it out
Posted: Thu Aug 27, 2020 12:22 pm
by TRDxB2
Posted: Thu Aug 27, 2020 2:01 pm
by Steve Jelf
Looks like I copied John, but without the green base.
Posted: Thu Aug 27, 2020 2:45 pm
by Rjackson
How would I find this John Regan do you have his phone number or email thanks, Ron
Posted: Thu Aug 27, 2020 4:02 pm
by Steve Jelf
Ron, go to Extra Quick Links at the top of this page and click on Find a Member.
Entering his first and last name should get you the contact info.
Posted: Sat Aug 29, 2020 2:10 am
by SurfCityGene
Ron, If you look back up to the picture of Johns charger there is a link to another discussion. If you go there and scroll down to the bottom you'll see a post from John. It's easiest to contact a p[oster when you simply click on their name and you can send them a note directly.
Posted: Sun Aug 30, 2020 3:53 pm
by Rjackson
Again I would like to thank all you guys for your help. I have found the charger I need thanks to John Regan
